Home > Maintenance & Modifications > Gearbox, Transfer wading plug / breather
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi forum,
i am sure this has possibly been done to death - but with some conflicting information i wanted to confirm
Wading plugs are installed for wading an removed immediately after (or close to) is the purpose of the hole to allow breathing, oil release etc????
is it possible to fit a breather in place of the wading plug ?
Post #638366 19th Jul 2017 6:29am
Essentially, yes to both. I've seen wading plugs replaced with clear pipe breathers that allows any oil build up to be seen.
It's a double-edged sword though - if you are a serious off-roader then a breather from the bottom of the bell housing can be rather vulnerable.
Personally, I'd just fit and remove as necessary. It doesn't need to be every five minutes, though. You could, for example, fit at the beginning of a two week trip and remove afterwards. Darren
Post #638368 19th Jul 2017 6:55am
