Home > Series Land Rovers > Rocky Mountain door tops |
stephenh Member Since: 01 Nov 2015 Location: Bristol Posts: 3 |
Have you tried fitting them yet? Mine foul slightly on the windscreen securing bolts, and they are also not quite as tall as the original steel frames so they don't seal as well. I'm also a bit annoyed with the catches that go in the frame to lock the glass; these stick out a long way and if you try to stick your head out when driving, it's too easy to get the catch hit you in the side of the head which is flipping painful!
I am considering making an alternative catch mechanism so that I don't keep hitting my head. |
15th Jul 2017 10:12pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2158 |
Either of you RM doortop owners know where to source a new piece of glass with the holes in it. Iv smashed mine, the rectangle rear piece. RM no longer exist in uk.
Keith |
4th Oct 2021 3:27pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1613 |
Sorry Keith, can’t help you however I have had flat windscreen glass cut to size so perhaps your local glass supplier may be able to help.
4th Oct 2021 7:34pm |
No good thanks. I can get the glass from other series makers but they don’t have the 2 holes in the glass for the latch.
Keith |
4th Oct 2021 7:36pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
A good glass place will be able to drill them i think
4th Oct 2021 7:42pm |
