Home > Td5 > Td5 2004 orange liquid leak |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Coolant leak, possibly from the steel Bung under the exhaust manifold?
Have you checked your expansion bottle level? Also a quick check of all hoses wouldn't go amiss by the looks of it! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
15th Jul 2017 3:57pm |
coolant leak check top hose from head to the rad
15th Jul 2017 4:28pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Definitely coolant....as above
15th Jul 2017 6:12pm |
neverin Member Since: 26 Sep 2016 Location: worksop Posts: 47 |
ive been tightening the jubilee clips on the coolant pipes but there is still some weeping from both places, i take it the jubilee clips should work?
5th Aug 2017 6:19pm |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 |
I used the Landrover clip and a jubilee clip on the top hose, prime place to leak.
5th Aug 2017 8:19pm |
5th Aug 2017 8:20pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
as its a 2004 it may be that the hose is ready to be changed and is damaged due to age where is seals. New hose, clean up where it fits (if needed) new clips and its all good to go DEFENDER 90 TDCI XS,
6th Aug 2017 6:14am |
