Home > Maintenance & Modifications > INTERIOR window trim
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
will the interior side window trim from a tdci fit into a 300 tdi ? ,no window fitted as yet .
Post #637357 13th Jul 2017 7:37pm
zsd-puma
This in the rear i assume?
I would think it will, the body is the same inside. possibly need to drill a coule of holes for the fir tree clips at the bottom
Post #637359 13th Jul 2017 7:41pm
tolley
yes ,for the rear , I thought it would but was not sure .
Post #637365 13th Jul 2017 8:03pm
zsd-puma
I pulled the trims out of my 110 USW for some work last year, there's nothing different behind them that i could see, just looks the same as any other Defender. They hook on to the cant rail at the top and have about 3 fir tree clips along the bottom. Then the upper seat belt bolt goes through it. I think the only difference with TD5 ones is the small recessed bit halfway along for the forward facing seat brackets and there is a moulding at the back for the seat belt to come through.
(I realise mine is a 110, but the 90 ones are similar.)
Post #637369 13th Jul 2017 8:08pm
