Home > Wheels & Tyres > Any reason why not?
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Any reason why not?
We run a 110 which gets used off road (presently in Portugal on the trails) Now its running on standard boost's with standard MTR's all good. But where we live to get out of the drive it's a u turn & it's a quick road, also some real tight turns here on and off the trails. Thinking 30mm spacers & adjust the stops? Is there any reason not to do this? Or just live with it, opinions great fully received.
Post #631666 15th Jun 2017 7:42pm
No, there's no reason not to do this. It's a very common mod. Darren
Post #631684 15th Jun 2017 8:38pm
JOW240725
Adding 30mm spacers vastly improves turning circle, highly recommend. James
Instagram @suffolk_rovers
Post #631691 15th Jun 2017 8:58pm
Timcat
Many thanks for the replys, are there any guidelines on adjusting the stops? Is it just adjust to give a certain amount of clearance or do you have to take into account that it's going to be used off road & give it a bit more?
Post #631717 15th Jun 2017 10:33pm
JAY BOY
Wales
Easy to do just adjust lock to lock and make sure that tyres don't rub the inner arches.
Make sure you buy hub centric spacers Thumbs Up
Post #631720 15th Jun 2017 10:42pm
I set mine so that I can just slip a finger between the tyre and radius rod on full lock with the vehicle on level ground. This, I find, means that the tyre seldom rubs on the road but can at certain axle articulations off road, which doesn't bother me.
Every year the MOT tester tells me that the tyres on full lock are incredibly close to the radius rod and would fail if they touched, so I reckon I have got it as tight as practicable! I always make sure that there are no witness marks before the MOT, of course.
Post #631723 15th Jun 2017 10:57pm
Thon
I used to trial my 90 and 110 and deliberately had the lock stops set so that the tyres contacted the radius arms - that way you know you have the absolute max lock. Spacers and non-standard offset rims aren't permitted. I was lucky that the mot tester was in a part of Somerset that was rich in ARC members so they never failed.
Post #631748 16th Jun 2017 1:39am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Adjusting stops ..
After fitting spacers I marked a corner on each "stop" with white "Cutex" - and then adjusted 2.5 turns.
Post #631751 16th Jun 2017 6:03am
JOW240725
I have a set of Terrafirma hub centric spacers for sale Whistle
Also as a mechanical numpty has anyone got a photo that they can put a big arrow on pointing the the steer stops? Embarassed All this talk of radius arms goes over my head... Big Cry TIA Very Happy James
Post #631760 16th Jun 2017 7:04am
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
look at this page for full mode how to do and pictures to do stops:
http://defender90xs.blogspot.fr/2013/11/st...tment.html
Post #631779 16th Jun 2017 9:16am
JOW240725
proloForêt that's perfect! Thank you very much Thumbs Up Bow down James
Post #631783 16th Jun 2017 9:56am
Timcat
See PM
Post #632047 18th Jun 2017 8:42am
sako243
Bolt near the swivel
 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #632049 18th Jun 2017 8:51am
Timcat
Well all done, what a difference! Makes a massive improvement almost bus like, stopped in London the weekend so had chance to see how it got on with the tight spaces and very impressed.
Post #636796 10th Jul 2017 7:21pm
