Home > My Defender > 1993 Defender 110 CSW Rebuild |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2547 |
Not much progress further, but little steps will get me there eventually.
Got the axle stripped down so I could assess what needed replacing, seems I'll need new swivel balls/bearings/seals plus drive members and associated hub seals and gaskets but the rest will go again which is good news. All the axle end station parts have been cleaned up and painted where appropriate ready for reassembly onto the casing once the new bits arrive: Click image to enlarge I had to replace one hub as it had a broken drive member bolt stuck in there which had been partially drilled out off centre, but luckily I have a big pile of spare hubs so one was duly cleaned up and the new disc swapped over. I then spent the best part of 6-7 hours scraping and scrubbing with white spirit to clean the axle casing of all the Waxoyl and general muck. It is in good nick though and is now ready for rubbing down and repainting prior to rebuilding. Click image to enlarge |
25th Jun 2017 3:42pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Great progress so far the cleaning gets tedious but its definitely worth the work. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
25th Jun 2017 3:47pm |
Some more progress this weekend. Got front axle painted and fully rebuilt and the rear dragged out of hiding and cleaned up.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
9th Jul 2017 6:05pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10491 |
Great progress there Retroanaconda 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
9th Jul 2017 9:41pm |
Bit of a delay in updating this.
Both axles now rebuilt and rolling, positioned under the chassis ready to be mounted up once a big box of shiny stuff from Land Rover arrives. Got the fuel tank mounted in as well. Click image to enlarge |
27th Aug 2017 12:34pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
Looks great.. you'll be rolling it outside before you know it! :thumbs:
Will you be treating the inside of your chassis? reason I ask is that I have a Marsland Galv chassis and was thinking of applying some Dinitrol cavity wax to the inside.. 1993 200Tdi Defender 90 |
27th Aug 2017 4:20pm |
Here's hoping, need to do timing belt on the 90 so will need the chassis mobile so I can use the workshop.
Might stick some cavity wax in if I can be bothered, we'll see. |
27th Aug 2017 5:23pm |
Chassis now mounted on the axles
3rd Sep 2017 9:35am |
Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142 |
Coming along nicely, wish I had the room to attempt something like this👍
Good luck with the rest p.s. Just double check where those doors were from you never know? https://www.google.co.uk/amp/www.bbc.co.uk...e-37220084 ?? |
3rd Sep 2017 10:56am |
Thanks. The doors have been in my workshop for 6 years or so. They also came from a proper commercial scrapyard, not a pikey outfit, so I'm pretty confident that they're above board.
3rd Sep 2017 12:07pm |
Excellent work keep loads more pics coming please Ray
3rd Sep 2017 12:32pm |
Work of art, great progress 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
3rd Sep 2017 10:36pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
great progress there! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
3rd Sep 2017 11:06pm |
Put the engine in the chassis this weekend, fits nicely so far
10th Sep 2017 2:19pm |
