Home > Td5 > Renewing windscreen and alpine/rear window seals... |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
My 52 plate TD5 CSW is leaking through the perished alpine windows in the roof, as well as the rear quarter windows. The windscreen surround is bubbling and the windscreen needs to come out to rectify.
I'm quite happy to do the work myself, and will use the drawstring method widely described on various websites. I will be using genuine parts for the new seals. My question is, what additional sealant compounds do people recommend? I don't think LR used any additional sealant when it was new, hence the reason why most of them leak perhaps? However, all the methods I have seen use copious amounts of washing up liquid or Vaseline which surely would compromise any sealant used? Also, it could be very messy using beads of silicone/sikaflex when fitting. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
12th Jun 2017 9:22pm |
Don't bother with washing up liquid as its not needed if you take your time. Also use none setting windscreen sealer, just pop into your local car window fitter and buy a tube off them. It is messy so have lots of cleaning gear to hand when doing the job. Ray
12th Jun 2017 9:38pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
The rear quarter windows have the tube in the rubbers on the inside. I believe the alpine lights have that too.
They are very easy to change and if the aluminium is in good condition you don't need additional sealant. To the persons that say don't do it yourself I would say: If you can't do this don't drive a Defender use public transport. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Jun 2017 7:05am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2159 |
I fitted a new screen/surround in my 110.
My advice is this. Forget washing up liquid etc just wait until you actually start to cry with frustration trying to get the screen in, and then use your tears as a lubricant....it works well. Although be sure to wash them off when you have finished as tears have salt in them and it may promote corrosion. |
13th Jun 2017 9:36am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10355 |
If you're using new rubbers, you wont need any sealant in theory. The string tecnique won't work for your alpine lights. You need a filler trim tool to fit them.
My thoughts are: get an independant one man band windscreen company (not Autoglass) to fit them for you, no hassle. For sealant, use Arbomast https://www.dortechdirect.co.uk/arbomast-a...eens.html/ |
13th Jun 2017 11:13am |
Or if you fancy a trip south, I can fit them
13th Jun 2017 11:14am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1748 |
Is that offer open to anyone Pie payment
13th Jun 2017 11:33am |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 131 |
Click image to enlarge hi. Just tried my luck at changing the windscreen seal yesterday. Good 6 hours of fettling about ;( but i am not aware of any screen fitters on the island where i live. i followed some of these steps (i cut the lip of the seal from inside to remove) https://forums.lr4x4.com/topic/10238-defen...placement/ I know the screen is not perfectly square/rectangular but is the seal manufactured to compensate that or it is just a big loop? The joint on the seal ended up at the top centre of screen as opposed the lower centre in the case of the perished one i am kind of worried. Once the seal was on the glass it was a bit loose on some areas (but from experience in the aluminuim profile industry rubber seals tend to shrink across time - and it is very sunny here in malta.) Some concerns: Can the filaments of the heated screen be pourous and draw up water? I had a hard time putting seal on the glass while on the table. and applied water and soap when installed i noticed a foggy part (about 1cm in height acros some part of the lower side). See Photo. Another concern is once ready i pressed a bit around the edges to see if the screen is properly seated. on the upright sections the screen is solid in its place but at the bottom it can shift inward and outward a few mms is that normal? at some point while doing this i heard a faint crackling sound ;( .... Comments? joseph |
8th Jul 2017 4:14am |
