Home > Technical > Transfer Box Gasket
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Transfer Box Gasket
I noticed that LR replaced the sump gasket on the LT230 with sealant. Now I have a very small leak, actually rather a small drop but want to fix it sooner than later. What is the recommendation? Using gasket and sealer or sealant on its own? Cheers m
Post #632366 19th Jun 2017 10:23pm
pannawonica
Australia
I thought I had said leak, however it turned out to be the intermediate shaft Oring! Big Cry
Post #632385 20th Jun 2017 1:50am
dorsetsmith
Sealant,Hylomar 607 as factory fitted
Not all LT230 have gasket fitted, but use sealant only on flange faces Exclamation
Post #632396 20th Jun 2017 7:45am
