Home > Maintenance & Modifications > MAF cleaning spray. Worth it? Then pilot correction? |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
You shouldn't need to re-set anything, The ECU should automatically correct for any small changes in the MAF readings...
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
24th May 2017 9:09am |
I would have thought it would be calibrated for a clean wire and then progressively read lower than actual air flow, then go back to 'normal' upon cleaning?
Or in other words it'll correct when cleaned, but not as it's getting dirty. ? Solved the bowel problem, working on the consonants... |
24th May 2017 9:17am |
The MAF will be designed to read over various conditions, All the happens is when they get dirty they take an 'offset' that can mean that the airflow measured won't match the actual airflow... By cleaning it, It should loose the offset (if it has one)... However, please be careful as it's very easy to damage a MAF....
24th May 2017 9:27am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2586 |
I just use carb cleaner, no issues. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th May 2017 9:28am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Carb cleaner, brake cleaner, any solvent based cleaner that will remove oil based deposits.
As said, ecu will revert back to normal conditions after cleaning, you don't get re learn options for either MAF or MAP sensors. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
24th May 2017 10:11am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
http://www.ebay.co.uk/itm/Holts-Brake-And-...SwbqpT6gNH
That'll do you for next to no cost, I've done this just a few weeks ago with the MAP and MAF and you WILL notice the difference in performance. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
24th May 2017 2:06pm |
My intention was more that the pilot correction relearn would relearn the settings related to pilot correction, but in the new context of a cleaner MAF. (I relearned last with a dirtier one) Anyhoo, did this today, the solvent was the actual stuff, CRC brand - on special While I'm well aware of my propensity for confirmation bias, I'll still say it 'felt' like things were improved, sounded smoother, the engine was having a good day, if you know what I mean Solved the bowel problem, working on the consonants... |
3rd Jun 2017 5:17am |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
The technology in the MAF is a form of a hot wire anemometer[1]. The wire is heated and the drop in temp is measured. The wire is often very thin and prone to damage.
If it gets coated in oil/dirt then that will insulate it slightly and give you lower airflow readings. A quick clean with some solvent on a regular basis is wise. Jack [1]https://en.wikipedia.org/wiki/Anemometer[2] [2]https://en.wikipedia.org/wiki/Thermal_mass_flow_meter |
3rd Jun 2017 12:01pm |
