Home > Technical > Defender Puma 2.4 110 2007 Throttle overrun |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 231 |
Had a similar problem to this and it was the clutch switch. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
12th Dec 2014 7:12pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Check your brake lights, if they aren't working check your fuses as a blown fuse for the brake lights can can cause this seems to be a pretty common issue and most people have this happen just after using the towing electrics
12th Dec 2014 7:49pm |
Discodai Member Since: 16 Jan 2011 Location: Mid Wales Posts: 3 |
Thanks all. Brake light fuse was blown. All ok now. Discos are good…..Defenders are great!
1993 Discovery 200TDi owned from new 2007 Defender owned from 2010 1994 Rover Mini 35 owned from 1997 |
13th Dec 2014 4:33pm |
14th Dec 2014 3:00pm |
Limestone Member Since: 19 May 2017 Location: Cotswolds Posts: 2 |
1st search on here and instantly found this thread and the solution to my throttle over run
how could a brake light fuse cause so much trouble! amazing thank you bga86 the power of the internet |
19th May 2017 9:36am |
proloForęt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 |
Limestone,
Thank you to find this for me. I have also this issue but no propblems with my brake lights. I now try to understand what is the "clutch switch" Léo |
19th May 2017 10:13am |
Léo there is a thread on here that explains the Clutch Switch
here http://www.defender2.net/forum/topic579.ht...tch+switch and a post that goes
hope that helps |
19th May 2017 10:46am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19454 |
Failed clutch switch.
I've disabled mine completely, better drive without it and a better driver input. However, it isn't just a case of unplugging it on a Puma. Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
19th May 2017 4:31pm |
Thank you for these replies and links. I am going to investigate this weekend.
Custom90steve, did you bridge the two wires? I am thinking of installing a "scotch lock" on these two wires will create the solution. |
20th May 2017 7:06am |
Yes. Bridged.
You could use your method but if you buy the connector and bridge it like that it'll be fully waterproofed and the harness left in-tact. The connectors are only around Ł6, but maybe a little more fir you in France? I used a male and female, one to blank and seal the clutch switch socket. (Use sealed the wire entries at the rear.) And bridged with wire loop the harness plug and tied it away nicely. Throttle has a much better response, no MIL or DTC's. I've been running this for at least 500 miles now. Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
20th May 2017 10:16am |
These are the connectors, 2-way.
https://www.autoelectricsupplies.co.uk/product/680 Don't forget the pins and seals. Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
20th May 2017 10:18am |
Thank you. Good advising - keep the wiring loom unharmed.
20th May 2017 12:12pm |
20th May 2017 12:59pm |
I want to say thank you again for this tip!
The connectors arrived with me yesterday and I do the technique. The problem of the revs is completely gone now and it is much better driving experience! I recommend all people with this system do this fix. merci. |
1st Jun 2017 5:46am |
