Home > Maintenance & Modifications > Steering wheel boss doesn't fit?! Help please!
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
I did ask on another post but decided to start a fresh one!
I bought a boss that came with a wheel, it's the right number of splines and slides on okay but the boss hits the steering column.
See photos - in only a few turns of the wheel you can see where it's worn the plastic.
It's like the edges of be boss are too deep?! Any suggestions?! My car is a 2009 Puma.
I've tried it on my dads 2003 TD5 and it works on that. It's like the shaft doesn't stick out far enough in comparison.
Suggestions welcome! Thank you.
Post #623757 12th May 2017 10:44pm
JAY BOY
Wales
Question
Post #623760 12th May 2017 11:01pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Check column shroud is correctly fitted 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #623761 12th May 2017 11:15pm
stuart123
Thanks. How would I check that?! Don't even know what it is....
Post #623762 12th May 2017 11:17pm
pj2106
The plastic cover that it's rubbing on is 2 pieces make sure it's fully to the dashboard might give you those extra few mm
Failing that space the boss or trim the cover
Or buy an optimil boss not heard anyone have issues with them 2008 110 2.4 XS Utility (Hagrid)
Post #623764 12th May 2017 11:36pm
stuart123
Thanks.... yes, housing seems to be in the right place...
Looks like I'll have to trim the boss in the first instance!
Post #623798 13th May 2017 8:42am
