Home > Technical > BBUS problems, 300Tdi |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
have you tried resetting the alarm?
It sounds a little like the alarm wasnt disabled and as such the BBS will go off until you reset the alram system, which should be as simple and rearming the alarm with everything shut and closed...assuming the fob is still synced to the car etc. (a flat keyfob battery may be out of sync with the car and needs to be cycled to get it back in line. Mike |
27th Apr 2017 3:56pm |
Oh if you can access the alarm ECU you will be able to turn off the BBUS and change some other settings on 300 discos you could change the alarm sound too. Mike
27th Apr 2017 3:57pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
If its the new Nanocom with the colour touch screen it can talk to the 10AS, if its the original then no. |
29th Apr 2017 8:09am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2639 |
If the BBUS is removed and not being used, then I have a home for it!!! 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
30th Apr 2017 9:08pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6031 |
Alas Mark.... the BBUS unit (eventhough it's plastic) looks as rusty as the rest of the vehicle.
And it clearly has a fault on it too. Apparently ex disco/rangie BBUS units will work on a defender (I'm not 100% sure but I think they do)... as I want one on mine too. |
1st May 2017 3:06pm |
, will keep looking for a BBUS unit then. 110 D250 SE HT
1st May 2017 4:50pm |
Any Defender/Disco BBUS should work, however be aware that the battery in the older ones up for sale may useless.
Do not get AMR4971, although cheaper it won't work, see this thread http://www.defender2.net/forum/topic35612.html |
2nd May 2017 8:26am |
They arent that expensive new Mike
2nd May 2017 4:49pm |
