Home > Technical > Smallest LT230 handbrake drum |
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 |
What about short shaft, disc brake and a spacer to make up the difference to the prop... there's no need to get another prop made as it needs to be longer! Also GPS speedo? RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
2nd May 2017 2:24pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I see now, I was thinking you meant it was catching the chassis rails !
On mine the X-Eng disk transmission brake fixed that problem, my transfer box is about 6 inches further back than normal and I had fitted a centre winch cradle below the floor so when I moved the xfer box back I couldn't fit the original drum in. The calliper is a bit tight to get in on mine but it's substantially shorter than the original assembly. I know in some versions the backing plate has a different orientation for the calliper due to a lack of space. You could also modify the plate or create a new one to suit. I can't think of any reason why the calliper couldn't be mounted at the side rather than the top and there looks to be enough clearance for the disk below the cross member if I'm interpreting the photo correctly ! I can take some measurements of mine later if you can't get access to one locally to have a look at. http://www.yorkshireoffroadclub.net/ |
2nd May 2017 4:36pm |
