Home > Puma (Tdci) > Adjustable Towbar Minimum Height
Page 2 of 2 <12
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Hi Stephen
That's great. Thanks very much. It looks as if the holes on the tow ball match the holes on the LR tow-bar fitted to your 90 without a need for drilling??? Am I correct??
Post #614164 3rd Apr 2017 8:15am
Cjwinyorks
Sammyboy that tow arm looks ideal for what I want.
In English I found it here.
https://www.rameder.eu/universal-ball-head-4-hole-122042.html
My only question :- is it alko suitable, with the required longer neck under the ball? I can't see any such detail.
By any chance do you know?
Chris.
Post #618454 21st Apr 2017 4:54pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
That dropped ball, although sounding somewhat medical, sounds a good solution for solving the problem of a slightly too high towball. I've just emailed Thule UK to check on availability here, suitability (I'd want to use it on the LR height adjustable towbar as opposed to the slider), and cost. I'll post the response, if any. I couldn't open the link posted, sadly. Ian One wife - livid
Post #618486 21st Apr 2017 6:29pm
Sammyboy
Thule or Brink???
Hope you have better luck than I did. Thule replied saying all there tow products are now dealt with by Brink. Emailed Brink two weeks ago and still had no reply 😬😬
Post #618493 21st Apr 2017 6:49pm
IanW
There's a Thule specialist called Motaman listed in Bristol. I've emailed them as well, and once again will post the response, if any. Ian One wife - livid
Post #618498 21st Apr 2017 7:04pm
zsd-puma
Thule have sold their towbar division to Brink
Post #618524 21st Apr 2017 8:26pm
xtr2turbo
United Kingdom 2016 Defender 110 Puma 2.2 USW Corris Grey
I have the thule drop ball
I bought online from Germany
just to flag that the bolts are smaller than standard defender
I does fit the four holes in the tow braket but it is smaller holes mating to bigger holes which was a concern.
You need thick washers to spread from behind to fit the nuts supplied
Post #618555 21st Apr 2017 9:40pm
IanW
Ah .......... that smaller bolt size would put me off, unless it was possible to drill out the holes a bit without effecting the integrity. Ian One wife - livid
Post #618617 22nd Apr 2017 9:52am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I wasnīt absolutely sure, but just went out and checked. My Thule tow ball was supplied with a generously dimensioned 8 mm steel backing plate and four 10 mm bolts. The original tow ball only has two 12 mm bolts. The 10 mm bolts in 12.5 mm holes, are well looked after. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #618865 23rd Apr 2017 11:50am
Sammyboy
Chris.
I agree it looks just perfect. However, like you I would like to know from anyone if this is compatible with an ALKO tow hitch on a caravan.
Post #620380 29th Apr 2017 2:50pm
Wild Card 90
I just asked my son who towed a rented 2016 Hobby caravan with our 90, last summer. It was fitted with the standard anti-sway towing mechanism, but he couldnīt recall if it was from ALKO. He had no problems whatsoever. It clamped down fine.
The horizontal distance from the tow ball to the bracket is 47 mm, if that is any help. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #620397 29th Apr 2017 4:20pm
Cjwinyorks
Thanks. The alko towball is different in having a longer neck. The hitch will attach and be fine in 95% of times to a normal one, but in certain extreme towing circumstances can hit the neck bottom and unhitch.
But it does look like it has the longer neck
Post #620404 29th Apr 2017 5:08pm
Page 2 of 2 <12
