Home > Puma (Tdci) > Check your heater hoses... |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Wasn't there a recall for that lifting eye to be removed? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
13th Apr 2017 1:13pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Not sure Shaggy?
My 08 still has one, and I've never seen any with them missing as yet? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
13th Apr 2017 1:30pm |
slightly different layout in LHD's for anyone following
13th Apr 2017 1:49pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
James
13th Apr 2017 2:48pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7681 |
great, thank you for posting will check Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
13th Apr 2017 10:27pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19527 |
I think there was a recall..
Mine however, still has the bracket and I've checked mine and no issues. Seems to affect some, and not others. Turbo hose clearance between it and the steering shaft is another to watch. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
13th Apr 2017 10:33pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
No recall for that, although the more common problem was the bracket working loose and rattling or falling off. Many brackets either fell off or were taken off for that reason. |
13th Apr 2017 10:37pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2287 |
Thanks ian series 1...
I have a MY2011 90 and will check tomorrow...but I've been all over mine and are currently convinced that I don't have this lifting eye fitted, mines a Dec 2010 registered model...so maybe this was dropped at some point... SKIP https://www.defender2.net/forum/topic83242.html |
13th Apr 2017 10:39pm |
It might have been a TSB (i've not checked) rather than a recall.
These are just where LR have identified a common problem and found a solution, but owners of vehicles aren't specifically notified unless they report the issue or it's found at the time of a routine service. |
13th Apr 2017 11:58pm |
It's possibly an item that was used for assembly, but supposed to be removed once the engine was dropped onto the chassis, but on some they probably forgot. |
13th Apr 2017 11:59pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
ill have a look today thank you
14th Apr 2017 9:30am |
It does seem a bit odd?
I've just checked mine and the hose is a good inch away from the lifting eye, Whereas the one I did yesterday was very tight to the bracket? There is only one hose listed, so not sure why some do and some don't? Maybe down to whoever fitted them at the factory? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
14th Apr 2017 9:58am |
