Home > Technical > Bulkhead/Windscreen Bracket
Page 2 of 2 <12
AMBxx
I had the same problem after 14 months. After much debate, I just went for the Gore replacements. By the time I've messed about with the dealer my time is worth more than the £90.
On a grey Defender with Black Pack, having black windscreen brackets looks really good too. Just wish they'd hurry up with their replacement door hinges.
Post #609575 15th Mar 2017 10:03am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Just been on the Gore website and there's a link to there faceache screen, door hinges for the 90 will be available soon @ £330 plus postage Shocked sets for the 110 will be £650 plus postage Shocked , hope there a good product for that price. Cogito ergo sum
Post #610820 20th Mar 2017 10:00am
AMBxx
Big Cry
Maybe I won't be buying after all! I'll just revert to plan A of converting the bolts to security bolts with some metal putty.
Post #610823 20th Mar 2017 10:24am
nitram17
Re: Bulkhead/Windscreen Bracket
mse wrote:
I know its a common affliction - but serious the car is only 16 months old and ive noticed the corrosion setting in! Shocked
the $64000 get the gore replacements or get the dealer to fix it (or both!)
its got to go back for some normal warranty paint work anyway - in fact the thing keeps going in for paint defects!
In my opinion its galvonic induced corrosion .....the aluminium bracket is small (anode)and is atttached at one end to a aluminium windscreen frame and at the other to a large steel bulkhead(cathide),the bracket is being sacrificed especially where the ali bracket is attached to the bulkhead. It does not help that the original gasket is posh cardboard allowing moisture to aod conductivity across it. You need to use some anti galvonic paste such as moly ceremac or the like .....it doesnt matter how well the bracket its painted and it helps if you paint the bottom surface of the bracket ,but if you dont block the moisture it will corrode eventually .Most appear to corrode even in the pre ford days when they used to paint them properly.
Post #611541 23rd Mar 2017 2:33am
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
HELP..
I have this corrosion problem on my 2 -year - old Defender. I had it on my 2013 version - and they fixed them under warranty, no problem.
This time, however ,they INSIST that the problem is a ''stone chip'' and REFUSE to do anything about it. When, quite clearly, the bracket is corroding under the existing paint.
They also add that " as there have been modifications" this also obligates them from any rectification. Pardon?. Modifications are minor and do not involve anything around that area.
Post #656812 12th Oct 2017 4:46pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hi myonehere,
Take a look at the Puma topic, and sockpuppets thread on 'how long to fix'. I have the same problem, but my dealer couldn't be more helpful today. Contact LR customer relations. Each LR garage is obviously different with regard to customer relations, and if it's the Droitwich dealer, loads of moans on this site about them, Sad
Best of luck with getting it sorted,
Andy
Post #656817 12th Oct 2017 5:11pm
myonehere
thanks for that .. this is Stratstone Cheltenham who, in the past, have been very helpful -but now truly hopeless.
I have now put it with LR customer relations.
Post #656825 12th Oct 2017 5:33pm
Ashbyandy
Look at the thread ' landrover customer relations' in the Defender section. There is a member on there who works for them, they are 'CRC@landrover',
Andy
Post #656829 12th Oct 2017 5:46pm
myonehere
Yes - done it now, thanks
Post #656837 12th Oct 2017 6:12pm
Page 2 of 2 <12
