Home > Technical > Rear shock absorber removal. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2545 |
No, just remove the wheel for access and there'll be plenty of room with the axle on a suitable stand. If the shock is gas-filled then it will try to extend once removed, so it'll need to be compressed down again to re-fit but this isn't difficult.
Lower nuts can be fun to undo if they've been on a while, I've had to cut them off before. |
17th Feb 2017 1:47pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
Thanks for that, they are the standard shocks, not sure if gas filled.
Hopefully the nuts will be ok 😳 Chris 2010 Defender 110 Station Wagon, Santorini Black. |
17th Feb 2017 2:11pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19525 |
You can do them in situ, no jack or anything at all. You can compress them by hand.
Bear in mind as I'm sure you are aware that there are torque figures for all of these findings. Bets replaced with new once removed ideally too. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
17th Feb 2017 5:08pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2024 |
This might also prove useful...
http://www.defender2.net/forum/topic40334.html Best of luck |
17th Feb 2017 5:17pm |
Thanks for the info guys.
18th Feb 2017 2:32pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
and here http://www.defender2.net/forum/topic13312.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
21st Feb 2017 10:05am |
