Home > Technical > Gwyn Lewis flange kit |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
The front diff oil seal on my TD5 is marking it's territory ... again !
Checked the breather and it is clear but put an airline on it a couple of weeks ago to make sure ! The only thing I can think of is the flange needs replacing as well. I have found this Gwyn Lewis kit which should do the job - I will have to remove the existing spacer if there is one. http://www.gwynlewis4x4.co.uk/product/disc...onversion/ Has anybody used this kit ? I would rather use something from a reputable person rather than some spares dealer sending me a blue box part !!! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Jan 2017 3:35pm |
Don't know yet James. Started looking at it this afternoon but frostbite got in the way ! The flange is the original and it has done a lot of off road work so I would not be surprised to find the shaft damaged or worn. As the breather is clear, I checked again today, I am at a loss as to what else it could be - dodgy seal is a possibility I suppose but the last one fitted was genuine LR.
I don't particularly want to strip it down and then have to wait for parts if needed. I know it is not a long job to do but I would rather get it done in one go in this weather. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Jan 2017 6:13pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
mine do a fair bit off off road and if the mud shield is there you shouldnt get any crud in behind on the seal. mine seem ok never had a failure on that front.
so breather removed and blown through? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
22nd Jan 2017 5:03pm |
Breather has been blown through but I am going to replace the tube as I have some new stuff here.
Got a chance to have a look today (in between gardening chores !) and the mud shield looks like it has been damaged at some point - one area looks like it has been pushed back towards the prop so I am wondering if the opposite side is distorted the other way and destroying the seal. The only way to see what really is wrong is to take the flange off, job for this week if the weather holds out ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
22nd Jan 2017 5:30pm |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
Bob. Which vehicle are you runnng? How many kms/mi have you done? Interested because my seal and flange are being replaced under warranty at 60 000km.
22nd Jan 2017 5:40pm |
This is on a 2001 TD5 90. 60K miles (96K km) on the clock.
22nd Jan 2017 5:43pm |
Update.
Took it all to bits this afternoon, only the seal to remove now. The flange shaft is marked quite badly where the seal sits so hopefully that is the problem. The Gwyn Lewis kit came today and is certainly a comprehensive kit and quality looks excellent. Should get it all back together Thursday. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
25th Jan 2017 4:36pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
If you have a groove were the seals sits then that is what is leaking. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
25th Jan 2017 5:26pm |
So JLR regs under warranty are .... replace both seal and flange....you can speculate as you like
26th Jan 2017 12:00am |
I can understand that. Probably cheaper to replace the flange to save return warranty trips.
I am glad I got the flange, apart from the fact the old one was marked anyway, as the last person who took it off (not me !) kindly put Loctite on the splines ! It took a lot of persuading with a rubber mallet to remove. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
26th Jan 2017 10:32am |
Finally got to finish this today and I think the answer to the problem was a botched job by the indie I use - that should now read used to use !
When I took the flange bolt off I was surprised it took virtually no force at all. I had heard the horror stories and had a good supply of explosives ready to shift it First issue was the garage had used Loctite on the flange splines so it was a pig to get off. When i went to remove the seal this morning something did not look right. The new seal I had was the same as the one fitted and has a lip on the inner seal which should be flush or slightly below the diff case. I think you have guessed where this is going, the old seal had the outer edge flush with the case meaning the inner seal lip was trashed in the mud shield and the flange was not fully fitted hence the reason the bolt almost fell out. On cleaning the area where the seal fits I noticed there is a ridge which the seal should rest against and it stops the seal hitting the bearing. Seal fitted, new drive flange ( which slid on easily after the Loctite was removed from the shaft !) and new retaining bolt torqued up correctly ! New prop bolts and new front axle breather tube fitted plus new diff oil. I don't know if the drive flange was damaged due to the bodge or not. Provided the seal is seated OK I can see no reason for the diff to leak now but time will tell ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Jan 2017 5:09pm |
