Home > Technical > Wiper issues (changed everything) still problems! HELP! |
Click image to enlarge Click image to enlarge Click image to enlarge have check these against 91 90 wiring ok, fuse box layout will difference but wiring colours are same and pin out same to the relay and motor too |
16th Jan 2017 6:45pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6477 |
Have you got a multimeter?
There are some tests you can do if you have. Let me know 1988 90 Td5 NAS soft top 2015 D90 XS SW |
17th Jan 2017 5:31pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Just a thought, you did obtain the correct - New Lucas stalk! as for a 1992 Defender there are two types one gives intermittent and one does not. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
17th Jan 2017 5:46pm |
Difficult to mix up the stalks as the two different types won't fit the indicator switch assembly bracket without modifying a clearance hole.
(I've got an intermittent stalk on the 1988 soft top) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
17th Jan 2017 5:52pm |
FLX1S Member Since: 17 Dec 2016 Location: North Wales Posts: 10 |
Thanks how do I do that? |
23rd Jan 2017 12:06pm |
Hmmm how can I tell? the plug was correct... |
23rd Jan 2017 12:07pm |
I'll double check! |
23rd Jan 2017 12:08pm |
