Home > Technical > Connector ident |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Headlamp levelling switch
If you get a switch fitted and get the motors on your headlamps, you will have another feature. Check in case you have them already. Make sure you get a Defender switch and NOT a Disco 1 one. They look the same, but have different connection and the different way round.....it just doesn't fit ! Blue one is not a connector, but a means of joining lots of wires together into same circuit called a Header joint. Last edited by Romadog on 16th Jan 2017 10:36pm. Edited 2 times in total |
16th Jan 2017 10:18pm |
natural colour plug
headlight levelling switch plug |
16th Jan 2017 10:27pm |
Baffled 1 Member Since: 09 Feb 2012 Location: Brailes Posts: 34 |
Excellent thanks for your help
16th Jan 2017 10:30pm |
