Home > Maintenance & Modifications > windscreen removal
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
windscreen removal
what's, needed to remove the windscreen surround , looks like mastic around the top part , hinges ,vents .
is it much of a job ?
Post #592534 12th Jan 2017 7:51pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
There's a lot of info here:
https://www.google.co.uk/search?q=defender...hCQtQHM%3A Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #592544 12th Jan 2017 8:41pm
jst
is the roof off?
assuming yes then just undo the bolts either end coming up from bulkhead if not then you need to undo line of bolts with captive nuts from inside behind headlining, remove the visors and mirror support, undo the two top side bolts and then cut through the sealant between roof and screen surround then it will lift enough (with someof the rear panel roof bolts loosened ) to get the surround out. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #592585 12th Jan 2017 10:22pm
tolley
thanks for the reply's ,roof not off was hoping not to .
Post #592592 12th Jan 2017 10:32pm
