Home > General > Edge Trim for metal edges
madfrankie
England 2007 Defender 90 Puma 2.4 SW Stornoway Grey
Any body know where I can find the trim(Rubber strip normally) that is sometimes used to hide sharp edges?
I need to cover the old section of bulkhead edge
around the wheel arches (where bulkhead was removed.
Any pointers would be greatly appreciated
 "Of Course, Of course, I ain't asking . I'm telling!!"
Post #592384 12th Jan 2017 10:39am
Stacey007
Any good... you can get different thicknesses and types.
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
I used similar very small stuff to put round the sharp edges of the amo box I made..
Post #592394 12th Jan 2017 11:09am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Take a look here -
http://www.ebay.co.uk/usr/themetalhouse201...2749.l2754
should find something suitable Thumbs Up
Post #592395 12th Jan 2017 11:09am
rallysteve
United Kingdom 2003 Defender 110 Td5 DCPU Chawton White
http://www.woolies-trim.co.uk/c-39-edge-trims.aspx 02' 110 TD5 Double Cab
Post #592408 12th Jan 2017 11:53am
madfrankie
Thank you both.
"Spot on" "Of Course, Of course, I ain't asking . I'm telling!!"
Post #592458 12th Jan 2017 3:24pm
custom90steve
Some of that edging strip is pure rubber, some is reinforced with a sort of nylon fibre.
The reinforced type is harder but much more hard wearing, pure rubber will wear easier. Watts Volts = Amps.
Amps X Volts = Watts
Post #592462 12th Jan 2017 3:34pm
LiftedDisco
'Ere you go...
Parts porn for the grown man...
http://www.carbuildersolutions.com/uk/
Everything you need!
Post #592543 12th Jan 2017 8:37pm
rallysteve
Just be careful about postage from CBS. I have been screwed for about 8 postage on a sensor from them before!
Steve 02' 110 TD5 Double Cab
Post #592563 12th Jan 2017 9:36pm
custom90steve
^^^^ This applies to d*rite shop too, small item will cost you dear.
Maybe VWP might have something suitable? Watts Volts = Amps.
Post #592567 12th Jan 2017 9:39pm
madfrankie
Well,
I went for the woollies option and it arrived today so fitting at the weekend.
Pix to follow.
Also fitted various new aluminium bits (indicator stalks etc.
so pix of them too.) "Of Course, Of course, I ain't asking . I'm telling!!"
Post #592832 13th Jan 2017 4:46pm
Site Copyright © 2006-2017 Futuranet Ltd & Martin Lewis
