Home > In Car Electronics > Water in Fuel warning light
boode
England 2003 Defender 90 Td5 HT Rutland Red
The Dashboard symbol for "Water in Fuel" has lit up and is not going out
Its on my Td5 - although the instruction book does not list this warning as existing
It usually lights when deep wading through water but goes out when it dries out
Now however it is on permanently
Google search says disconnect sensor on fuel filter - but I can not see any sensor on my fuel filter (located by rear wheel)
Is this just water in electrics somewhere or should I be concerned ?
Post #592212 11th Jan 2017 6:42pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
This is the sensor on fuel filter :
Part Number : WKW500060 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #592338 12th Jan 2017 2:33am
Fifth Horseman
The sensor shown above is fitted to the fuel filter drain (water collects at the bottom of the filter).
If, as you say, you don't have a sensor then there should be a spare connector underneath the vehicle that it would plug into - your comment that the light used to come on when deep wading seems confirm this.
The connector is 3 pin (econoseal type I think):
1 - Orange/Green - to warning lamp
2 - Black - earth
3 - White/Green - 12v ign from fuse 8 (also feeds the rear wiper)
You will probably find it is full of muck, a good clean out should sort it, make sure the connector is well waterproofed afterwards.
If you decide to cut the connector off then seal the cable ends, preferably with adhesive lined heat shrink tubing http://www.ebay.co.uk/itm/Adhesive-Glue-Li...VLMu8OgKDA
If joining cables then best to use heat sealed crimps like this http://www.ebay.co.uk/itm/Fully-Insulated-...-enluz6sDw or the non-solder variety http://www.ebay.co.uk/itm/Tyco-Solder-and-...rh9P2cnjfA
Post #592368 12th Jan 2017 9:52am
boode
Fifth horseman - you are correct
I have no sensor - just a very dirty plug
I will clean, dry and seal it
Many thanks
Post #592378 12th Jan 2017 10:21am
Theater
....or buy the sensor and you will know if you have water in fuel . Marco
Post #592389 12th Jan 2017 10:46am
boode
Will the sensor fit on to a filter that has never had a sensor - or would I also need a new different filter ?
I also heard that the sensors were not fitted to post 2001 Td5 so the truck has never had one fitter
Is water in fuel an issue nowadays ?
Post #592393 12th Jan 2017 11:07am
Theater
The sensor fits on your filter .
Remove the PLUG-DRAIN WATER (12) and and fit the SENSOR-WATER (3)
 Marco
Post #592419 12th Jan 2017 1:25pm
shaggydog
I wouldn't bother, its a really annoying and distracting feature as it will flicker occasionally which is why LR dropped them. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #592438 12th Jan 2017 2:09pm
Birdy
Personally I would bother, for once I can relate something positive. The warning light on my old TD5 came on, took it to the stealer, who undid the drain where mostly water poured out. Probably dodgy fuel, he suggested that before any drastic repairs I should fill the tank with new fuel, stop every mile or so on my way home and re-drain the it. Light went off never to be seen again...
But I wonder what would have happened if I'd continued with "watered-down" diesel?
Peter
Edited to add: mine was ROW spec; I wonder if they were fitted for markets where vehicles were more likely to be filled with dodgy fuel? Although this was in the UK!
Post #592443 12th Jan 2017 2:33pm
rallysteve
United Kingdom 2003 Defender 110 Td5 DCPU Chawton White
Retrofitted one to my 2002 TD5, has never falsly triggered the warning light. Peugeot diesels had these sensors fitted on fuel filters for years. I have had them several and they have illuminated a number of times when the filter contained water.
I would think it would be an advantage on a defender which is more likely to have a leaky fuel filler cap and travel through water than a mid 90s Peugeot estate!
Steve 02' 110 TD5 Double Cab
Post #592478 12th Jan 2017 4:16pm
Site Copyright © 2006-2017 Futuranet Ltd & Martin Lewis
