Home > 130 > Upgrades
Page 1 of 5 12345>
Naf
Kuwait
Upgrades
Hi everyone,
I recently purchased a 2000 130 from Germany, and the wait on shipping is killing me...
I already know i want to do the followin
Old Man Emu springs, 30mm lift front and 40mm rear.
LED lights
Fox Non adjustable shocks to suit lift
Alive stage 3/4 kit
P15 engine upgrade
NNN ecu upgrade
Single Mass Clutch upgrade
Cruise control
LR to RR wheel spacers
20x9.5 wheels
305/50R20 tires
Stainless exhaust manifold
3" to 3.5" stepped exhaust system
Front and rear larger brake rotors
X-brake E-brake upgrade
ARB diff covers
Air bags for extra capacity
I expect some of the mods are not advisable, but i have a lot of spare parts from previous builds, and thought why not use them on this build...
I am going to use this vehicle as a weekend ride, i will have 60% highway and 40% desert driving, the desert driving will be a mix of compact and loose sand. In the summer i pull a jetski and in the winter i haul dirtbikes...I also have a 24' boat i tow, but i may just use my Tahoe for that...
Post #584431 12th Dec 2016 1:57pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Re the lift, a 130 leans forward quite significantly already, so unless you plan on carrying heavy loads I would not lift the rear more than the front.
And re the wheel size: they must have considerable offset to not increase the already not very brilliant turning circle, but that will cause extra strain on the wheel bearrings.
Hope this helps, enjoy your 130! Defender 130 HCPU Td5 MY2000
Post #588549 29th Dec 2016 9:28pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Why single mass clutch? I have seen it in two cars - Def 110 and Disco 2 - both heavy loaded for hard offroad trips and botch ditched it back to dual mass. Without dual mass cars were rattling like a dog when engine was running on idle or a bit higher. From outside it was like there is something broken. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #588588 29th Dec 2016 10:48pm
BigRuss
If your taking a European spec defender to a hotter climate it might be worth thinking about the following.
R380 gearbox oil cooler
http://www.ashcroft-transmissions.co.uk/mi...r-kit.html
And high capacity sump for the lt230 transfer box
http://www.ashcroft-transmissions.co.uk/mi...r-kit.html Russell
2011MY 110 XS USW Black
Post #588604 30th Dec 2016 4:05am
Naf
Kuwait
Way ahead of you...
Already on order...
Here is another question, has anyone Twinchraged their LR Defenders?
Where as to add a supercharger before the turbo to give it more bite down low and keep the power going up top?
Post #591182 8th Jan 2017 8:49am
Naf
Kuwait
The dual mass is nice for comforts, but once you start pushin the power levels up, you better off removing it.
It will rattle a little, and it will sound a little odd, but them be the trade offs in the quest for more power.
Post #591184 8th Jan 2017 8:57am
Naf
Kuwait
Jetski in the summer, or dirtbikes in the winter.
I went with the 500kg 40mm lift OME rear springs, may get the 300kgs and use the airbags for similar results, and will get the 30mm front springs.
This way i raise the vehicle up just a tad, and gain the extra capacity.
I scored the MAXXTRAC wheels, 20x9 with a 10mm offset. Dont need wheel spacers, and will give me that little more room for the 305 tires...
Post #591185 8th Jan 2017 9:02am
MadTom
Both of cars I have experience with single mass were used for competition (not professional), so the power was not just a bit higher. And both went back for dual mass, without any problem. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #591517 9th Jan 2017 11:14am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
And yet I ran a Rakeway single mass flywheel for years. To be totally honest on my car there was almost no noticeable increase in noise or harshness and I would never go back to a dual mass if I had a TD5 again. 2001 90 HT 6.0LS/Auto
2014 90 XS SW 2.2
Post #591523 9th Jan 2017 11:59am
Naf
Kuwait
Dual or single, i have read that there really isnt any difference in driving nor comfort. Personally i prefer single as its less maintenance, and easier to service...
I found an exedy SMF and HD clutch, but GOOD GOD the price is higher than Rakeway's...
After talkin with Alive they set me up with one of their friends who specialize in clutches and he gave me a great price, with shippin to kuwait, But i feel i will have him ship it to Alive and let them crate it up with my stuff so i may save on shippin...
Post #592365 12th Jan 2017 9:50am
Naf
Kuwait
So i have been playin with the idea to twincharge my little beast with either a 1600 or 2300 whipple charger. I would put the whipple before the turbo charger as not to suck up too much hp to keep the boost up. The nice think about these whipples are they are thin, 100mm. And about 250mm long. So if i do install the aircon i can lay this right over it.
May need to bend the hood up just a little but i am fine with that.
I hope to get 5psi above idle and let the turbo kick in and take over.
The inlet is convienently in the rear and the output dead center of the lower side.I will have to fab custom inlets and outlets, but the beltin should be simple enough.
Post #594116 18th Jan 2017 3:53pm
Naf
Kuwait
Latest on my up coming project
Went with the Rakeway Brake system and flange hubs.
Have the followin parts on a ship bound for my port
Alive hybrid turbo kit
Alive Stage 4 tune
Ultimate Intercooler
P15 engine upgrade
NNN ecu upgrade
Poly bushing
Alive silicone hose kit
New style rear seat with striker
Front rubber bumper
KC LED headlights
KN air filter
102mm Airbox mod
P15 Engine with ported Head
Once I get more cash flow i will contact Synchrogearbox and order new Transmission and transfer cases.
On my order list i still have the following
Startech 48 spline steering wheel
TD5 Rev counter
decorative parts
PWR rad
Silicone Coolant hoses
Electric windows front and rear
Safety devices interior roll cage
Extreme 4x4 suspension parts, Swaybars, shock turrets, etc...
ARB larger fuel tanks, the 127ltr and 35ltr tanks.
For less than a new 2015 i shall make mine epic...
Post #616466 13th Apr 2017 8:31am
Nice, any photos? @v8_scumbag
Post #616502 13th Apr 2017 11:32am
bankz5152
Still disagree with signal clutch. Makes it a pig to drive, transmission shock and all sorts. My 110 is pushing 200bhp and 450nm standard clutch with no slipping or issues.
Post #616505 13th Apr 2017 11:49am
Naf
Kuwait
Ok, here is what i have to date
Allisport rad
Alive ultimate innercooler
Fresh 15P engine with ported intake, head and exhaust
Rakeway big brake kit
X-brake
20x9 painted gun metal wheels
305/50R20 Nitto tires
Wheel flares
Ac vents
Ac engine harness
Alive hybrid turbo
Led runnin lights
Kc headlight
Rpm gauge
Bezels
Front ac grill extention
Wolf front grill
Ss brake lines
Ome hd rear springs
My ride is stuck in customs, waitin on import approval.
After which its trial run to get a bench mark, and then complete teardown, rebuild the gearbox, transfercase and diffs...
Post #632447 20th Jun 2017 1:52pm
Page 1 of 5 12345>
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
