Home > Td5 > Water in Fuel warning light |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
This happens on mine, normally when it is dry and been nowhere near water !
The sensor is on the bottom of the filter and is quite easy to find, follow the wires. They stopped fitting them at some point after 2001. A lot of people do away with the sensor as they are unreliable at best. If you can't see a sensor connected to the bottom of the filter have a look around for a plug that has no home. If you find one it is probably the culprit and full of water or mud giving the false reading. I always ignore the warning and have had no problems so far. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
11th Jan 2017 7:37pm |
Click image to enlarge |
11th Jan 2017 8:24pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 421 |
Thanks Bob and Dorsetsmith
I have a dirty connector but nothing for it to connect into No sensor on filter So I will ignore the warning light |
11th Jan 2017 10:52pm |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
I stopped using super market diesel when mine came on and after a few fill ups the light went out and (touch wood) has stayed out. Adventure isn't paved!
24th Jan 2017 8:38pm |
