Home > Technical > Td5 Heated Rear Window switch |
Click image to enlarge 1 is Pos feed 4 is switch out to relay coil 5 is ground Click image to enlarge Last edited by dorsetsmith on 11th Jan 2017 6:15pm. Edited 2 times in total |
11th Jan 2017 5:41pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
Split to its own thread instead of with the tow electrics pinout
1. White/Green [WG] +12V Ignition feed from fuse 14 via header C0285 2. Red/Orange [RO] +12V illumination from fuse 20 via header C0290 and C0296 3. no connection 4. White/Black [WB] 12V output to heated rear screen relay coil and dash warning lamp via header C0286 5. Black [B] Ground for telltale lamp and backlight There seems to be an error on the 2002MY diagrams I have which has the ground connection on 4 in one place on the diagrams and 5 in another I have cross-referenced it with the Puma (same switch) and the Td5 electrical library and it is definitely 5. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
robtd590 Member Since: 28 Dec 2016 Location: Somerset Posts: 26 |
Thanks for your help guys.
I would like to use this switch to turn on/off an interior led light, I know they say it is not suitable for switching direct loads but do you think it would ok to operate an interior led light? Cheers. |
11th Jan 2017 9:33pm |
Absolutely fine for that.
The switches can't switch large power loads (e.g. heated screens) but they can handle reasonable loads - for example the heated seats are switched directly. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
11th Jan 2017 9:35pm |
Thanks for the info Martin, much appreciated.
11th Jan 2017 10:40pm |
You're welcome 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Jan 2017 10:41pm |
