Home > Td5 > 2001 TD5 90 Brake caliper rebuild |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
I've just overhauled my front brake calipers. I was only going to replace the discs but while I was there the calipers looked rough so they got done at the same time. I have 46mm pistons in the front. Are the rear ones going to be the same size, IE, same pistons, same rubber repair kit etc? Non ABS by the way. Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
30th Dec 2016 7:19am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Make sure you get the right diameter and length. There are plenty off options I found out. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
2nd Jan 2017 7:53pm |
