Home > Tdi > Air con questions |
Snagger Member Since: 12 Sep 2014 Location: Bedford Posts: 2 |
There should be two thermostatic switches on the thermostat top housing (200Tdi) or 180 elbow (300Tdi). One activates the electric boost fans if the engine temperature can't be controlled by the viscous fan alone, and the other will cut the aircon compressor out if the engine temperature rises further. The electric fans should not run continuously or respond to ac temperature, just engine coolant high temperature.
It sounds like your system is low on refrigerant gas and recharging is likely to fix it, but I would also closely inspect the condenser to make sure its airways aren't blocked. |
27th Dec 2016 10:18am |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 348 |
Thanks for the reply.
I had to learn the system to understand it and came to the same conclusion. You are right, she only needed some gas. |
29th Dec 2016 5:29am |
