Home > Td5 > another td5 alarm problem |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
If you replace the 10AS alarm unit, the new one will need pairing with the engine ecu and the existing keyfobs, so yes, diagnostic intervention will be needed, TBH though, I rather suspect the current 10AS is not faulty but has merely had a brain fart and lost it's configuration, unfortunately though it will still need a diagnostic device to set it up again.
The inductive coil communicates with the key fob rather than the actual key, the immobiliser function (and central locking) is all incorporated within the 10AS and is activated or not according to the vehicle spec. |
26th Sep 2016 9:51am |
and or send alarm unit to below and get it fixed
http://www.technozen-electronics.co.uk/lan...-services/ |
26th Sep 2016 1:49pm |
EWG Member Since: 20 Sep 2015 Location: Betws y Coed, North Wales Posts: 102 |
Heartily agree above.
Technozen's service is first class as I discovered last year. You will have fun removing the 10AS Alarm unit though - it's a horrible job, the right hand side self tappers are easy enough but as for the ones on the left.............. |
26th Sep 2016 7:26pm |
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 |
Hi all
thanks for your help I've contacted the guy you recommended with the link so hopefully will be sorted soon ! which brings me to a new problem I regularly take extended overland trips with my td5! so what happens if my alarm unit fails in the middle of nowhere is there any thing available that will by-pass the alarm unit that I could fit either if the alarm unit failed or before setting off on a big trip ? cheers kevin |
28th Sep 2016 12:27pm |
