Home > My Defender > An Anoraks Tdi Defender 90
Page 2 of 24 <123 ... 222324>
It was a miserable wet day today so I thought I'd do a bit of inside tinkering and sort out the speedo lights that had apparently fallen out. As is so often the way with Land Rovers though, it wasn't as straightforward as it seemed Rolling Eyes
The first thing I discovered was that both the instrument panel and the cowling behind were broken, which was a Censored . Then, having got to the speedo, I found that the white plastic collars that hold the bulbs in place had both been snapped off the back of the case. It looked like the whole dash had been clouted with something. The previous owner had tried to use aluminium tape to fix the speedo lights, and failed completely. Anyway, I fixed them with epoxy:
Then I also tried gluing the instrument panel but without success, so I've ended up buying a replacement from eBay. For the cowling, I've bought a metal replacement from Raptor Engineering to solve that problem once and for all.
So, what started out as a five minute job saw me faffing around for about three hours and then spending over £100 on parts Rolling Eyes
On a more positive note, I bought a TD5 clock to replace the existing chrome-bezelled Smiths one and elsewhere on the forum I've been told where to get the appropriate connector for it. Woo hoo. Darren
Post #563004 10th Sep 2016 9:23pm
Good news! The parts have started to arrive to repair my dash. First, an all but complete dash from eBay. The design of the warning light cluster suggests it's from a slightly later model. It also comes with a volt meter, which is an added bonus. This will get stripped and cleaned before re-assembling with my existing speedo.
Next is a new powder coated metal instrument cowl from Raptor Engineering, to replace the existing broken one. This is lovely quality and it's a shame it won't be seen once it's in place:
Finally for now, the connector for the TD5 clock that I've bought has also arrived:
The bad news is that all of these parts are going to sit in a box for a couple of weeks whilst I recover from a minor op:
Typing left-handed is a real chore Rolling Eyes Darren
Post #563657 13th Sep 2016 4:58pm
mk1collector
Those raptor cowls look good, let us know how it fits as I need one for mine really Thumbs Up the op looks like it was painful Big Cry Ray
My build thread
Post #563665 13th Sep 2016 5:47pm
Tiger
I think that instrument cluster is an earlier petrol one
Post #563672 13th Sep 2016 6:14pm
CarMan
90 looks very nice, enjoy and remember where there are some really good seat for it Wink Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #563677 13th Sep 2016 6:34pm
Heh, heh, thanks.
Will do and I've got some interesting pain killers Whistle
I'm not sure. The graphics are more subtle than my existing one and, apart from a missing '24v' symbol in the bottom right position, it's exactly the same as on mine. Darren
Post #563683 13th Sep 2016 7:00pm
Still on light duties whilst my hand recovers, but managed to spend a bit of time today dismantling and cleaning my replacement dashboard. I discovered that baby wipes are great for removing years of grime:
The only bits that I couldn't get completely clean were the heater graphics on each side, but I risked damaging them by trying to remove them, so abandoned that idea.
I also labelled up the wiring and took a stack of reference photos and notes before disconnecting Rolling Eyes
With a bit of luck, I'll get to reassemble the whole thing in the vehicle next weekend... Darren
Post #564820 18th Sep 2016 1:31pm
VeeTee
Netherlands
I successfully cleaned those graphics with pure Isopropylalcohol. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #564831 18th Sep 2016 2:42pm
Did you remove them from the plastic surround? It looks like they're dirty between the clear front part and the printed graphic but I'm assuming they're glued in. Darren
Post #564835 18th Sep 2016 2:57pm
VeeTee
Netherlands
No, I did not. Just cleaned them with a soft cloth with isopropylalcohol. Perfectly clean. Cheers, Vincent
MySite
Post #564837 18th Sep 2016 3:04pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
looks really good. makes me want an other rolling resto to keep me busy Whistle
Post #564846 18th Sep 2016 4:25pm
Thanks. The intention is really just a weekend toy. There are a few bits and pieces that do need 'restoration' - particularly the interior - but it is essentially sound. Won't be long before I can start the fun stuff of a few mods to personalise it.
Ok, thanks, I'll give it a go. Darren
Post #564849 18th Sep 2016 4:32pm
Instruments
I was finally able to make some progress today by re-assembling the instrument cluster. These things are never straightforward though. I spent ages chasing an obscure fault with the new warning light pack that I finally resolved by stripping the printed circuit off the original one and fitting it to the new one.
I painted the lower panel before fixing it to the new Raptor cowl:
The cowl is pretty cool and fits perfectly. Because it's much stiffer than the plastic part it replaces, it only uses four of the five original fixings. Also, whilst I had it all apart, I took the opportunity to clean 25 years of crud and dust from behind it Rolling Eyes
I picked up a powder coated, aluminium surround for the switches to the right of the steering column, again to replace a cracked plastic part, and fitted the cleaned up original switches to it:
And the whole thing back together:
The only thing I didn't do was run a suitable supply for the newly acquired volt meter, but that's a job for another day. Darren
Post #566619 25th Sep 2016 10:12pm
Seats
The other, far more satisfying, job that I managed to get done was to replace the front seats. I picked up a pair of very tidy standard seats in Techno trim from Jeffers of this parish to replace the completely shot vinyl originals.
Taking the old seats out was relatively straightforward - four bolts each plus the lap belt for the centre seat. I then spent a bit of time cleaning up the top of the seat box, again from 25 years of dust and debris, and cleaning up the salvaged bolts.
Whilst access was easy, I took the opportunity to replace a damaged seat belt stalk:
And then bolted the new seats in:
Eventually, there will be a cubby box in the middle but before then, there's more cleaning and then painting of the access panels and sound proofing to fit before, probably, a hardura finish. Darren
Post #566622 25th Sep 2016 10:27pm
Pickles
Love your work Anorak.
Top job,..looking forward to more "developments".
Pickles.
Post #566632 25th Sep 2016 11:12pm
