Home > Tdi > defender 300tdi and disco 300tdi differences? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
They're the same.
Mo The Land Rover 90 - Many are called, few are chosen. |
10th Sep 2016 8:19pm |
horus1970 Member Since: 27 Jul 2016 Location: north east Posts: 105 |
thanks mo, wasn't sure if head would be different where manifold bolts on with the disco not having the same turbo location, thanks mate.
11th Sep 2016 11:55pm |
They are the same engines horus, even the manifolds. It's the 200tdi that is different between defender and discovery.
Hope that helps Mo The Land Rover 90 - Many are called, few are chosen. |
12th Sep 2016 7:40am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16876 |
What's the difference for the 200tdi please?
I know that the exhaust manifold is different due to the turbo location, but is anything else different? |
12th Sep 2016 9:29am |
ah thanks very much mo, that's egsactly what I needed to know, cheers mate, |
12th Sep 2016 5:09pm |
@Blackwolf
The inlet and exhaust/turbo manifolds Timing case, additionally less the timing belt idler Injection pump brackets to suit lower FIP position Injector pipes Dipstick and tube Power steering pump Power steeing pump bracket Alternator bracket All the intercooler pipework The airbox Apart from that they're pretty much identical 😊 HTH Mo The Land Rover 90 - Many are called, few are chosen. |
12th Sep 2016 5:52pm |
... and not forgetting the water pump 😉 The Land Rover 90 - Many are called, few are chosen.
12th Sep 2016 5:54pm |
Thank you, very comprehensive answer!
I imagine that if one was considering retro-fitting a 200tdi into a series vehicle, an ex-Defender 200tdi is a better prospect than an ex-Disco version? |
12th Sep 2016 6:02pm |
Well they'll both work but the defender version will use all standard parts which always makes things easier. 😊
12th Sep 2016 7:19pm |
