Home > In Car Electronics > Defender 90 300Tdi instrument warning lights not working |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Probably a poor earth/ground connection? Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
24th Jun 2016 6:07pm |
The Hulk Member Since: 13 Apr 2016 Location: Aberdeenshire Posts: 81 |
There's a multi-plug in the engine bay which carries many of the warning light wires (see the first page of the ongoing thread in my signature). I had no handbrake or brake-wear warning lights showing when I turned on the 'ignition', despite the bulbs being good. I assumed the handbrake microswitch was duff but once I got a meter on it, I realised it was working too. Tracing the individual wires is a pain when they disappear into the loom but if you have a bulk of lights failing it might just point to that multi-plug being disconnected?
Welcome to the forum btw Mid Life; Live It! Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
25th Jun 2016 9:47am |
this may help
25th Jun 2016 1:20pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
Check the earth connections to the warning lamp pack. The two you can see working do so because they are not earthed at the instrument pack. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
25th Jun 2016 1:54pm |
quantumfoam Member Since: 20 May 2016 Location: Newcastle Upon Tyne Posts: 12 |
Sorting out the earthing has solved all the problems on the warning lights except one. So thanks for the help its much appreciated including the wiring diagram.
27th Jun 2016 12:11pm |
Which one? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
27th Jun 2016 12:13pm |
The L/R indicators warning lights don't flash although the tow warning light comes on once when the first L or R indicator is used. I can live with this as I don't use the tow point and the actual indicators are working but if you have any ideas they will again be gratefully accepted.
I bought the Land Rover as knowing it would need constant work and am retired so it was something to keep me busy. Proving to be an interesting challenge which I don't mind and am up for it LOL |
27th Jun 2016 3:05pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Check to see if all the wires are Ok on the hazard warning light switch. I had a similar problem and traced it down to that switch. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
27th Jun 2016 3:11pm |
27th Jun 2016 3:21pm |
Checked the wires at the back of the switch and one of the black wire spade connectors seemed loose so fitted a new spade connector pushed it on and the indicators now work fine. You guys are magic thanks a lot saved me a lot of electrical heartache
28th Jun 2016 11:52am |
Lets see your motor sometime.
From Geordie in exile. Jeff Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
28th Jun 2016 12:26pm |
Click image to enlarge Click image to enlarge This is the beast although my granddaughter has nicknamed it "Hot Wheels" |
28th Jun 2016 2:34pm |
Nice, lots of toys. Jeff
28th Jun 2016 2:50pm |
