Home > Tdi > water in cab |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Main culprits would be seals between cab and bed or the window seals. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
19th Jun 2016 1:19pm |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 |
Sorry guys, this was meant to be on Td5 section.
19th Jun 2016 1:20pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2062 |
Park it facing up ?
Mo 😉 The Land Rover 90 - Many are called, few are chosen. |
19th Jun 2016 3:09pm |
Haha get water in through the head lining then
19th Jun 2016 5:30pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
They leak in the same places, doesn't matter which engine! |
19th Jun 2016 6:29pm |
seal leak top cab rear window had same problem
problem fix now and no need for drain hole Last edited by dorsetsmith on 20th Jun 2016 8:58am. Edited 1 time in total |
19th Jun 2016 6:31pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 746 |
The drain holes by the seatbelt reels must be blocked or they maybe forgot to fit them at the factory, better get the drill out and retro-fit them
20th Jun 2016 8:49am |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
I had a leak in same area coming in from the rear window,due to the channel strip perishing
I used some new double glazing window strip from my neighbour which sorted it out, although it did stop you opening the slide window. I never used it anyway and you couldn't see any difference. |
20th Jun 2016 9:15am |
channel strip perishing, that the problem i had with my one but the leak was the window to cab seal at the top
20th Jun 2016 10:01am |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 |
drill some holes My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey 2 years off the road, but getting close to completion now
20th Jun 2016 10:24am |
Thanks guys, it's got 4 holes with plastic grommets in. Can someone post a link for the seal for the window please.
20th Jun 2016 8:06pm |
I was told I would have to buy the whole unit when I enquired with Craddocks.
so I patched it with double glazing strip into the window channel. |
21st Jun 2016 8:00am |
