![]() | Home > General > Bad Habbit |
| chalky Joined: 09 May 2008 Location: Yorkshire Posts: 152
No you are suposed to set off in 2nd.
| mrwoo Joined: 03 Jan 2008 Location: Cheshire Posts: 80
Where did you get that information from? |
| AndrewS Joined: 10 Apr 2007 Location: Pembridge Posts: 371
I think that you are supposed to start off in a 'suitable' gear. Why not 1st? |
I only set off in 2nd when I want a quicker get away, off junctions etc. |
I was told that setting off in 1st was for pulling away with a laden trailer on.
| Ads90 Joined: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 56
I set off in 2nd whenever I can - it does help speed things up, particularly on fast roundabouts.
| Grockle Joined: 24 Nov 2008 Location: Derbyshire Posts: 104
As long as your not sliiping the clutch excessivley starting off in 2nd shouldn't cause a prob. |
| austen Joined: 10 Mar 2008 Location: Sydney Posts: 16
When I attempt to start in 2nd on the level there is vibration until about 1500rpm. Does anyone else find this, or is a 2nd gear start smooth?
It's a smooth start now, but took a bit of practice... I keep the revs low-ish so I can fully engage the clutch early on, then it's a little juddery for a second until the revs pick back up, then you're away.
Yes, mine's a 110. I suppose revving to 1500 before letting in the clutch may avoid the vibration, but I like the smoothness afforded by the software during a 1st gear start.
| jst Joined: 14 Jan 2008 Location: Taunton Posts: 162 |
| red Defender Joined: 11 Feb 2008 Location: Cornwall Posts: 35
I would doubt it. I agree with AndrewS, start in a suitsble gear. Personally I always use first unless pointing down hill. Slipping the clutch when not needed seems to be wrong, and why would you want to wear out something that will cost a lot to replace. |
It must be mine then because i can set off in 2nd gear without slipping the clutch. Hence not wearing it away !
Same here - no more clutch slip than when starting in 1st...
| All times are GMT |
