![]() | Home > General > Cargo Barrier options for 08 Defender |
| dm_td5 Joined: 20 Jul 2008 Location: Northern Territory Posts: 120
I'm after a cargo barrier for the Puma. My Tdi Defender has a Milford barrier and both my Disco's had the Milford fitted (the first one saving our lives).
Thanks.
| El Cyd Joined: 21 Sep 2008 Location: bristol Posts: 17
No its an 2008 Defender and the line of rivets was on both this one and on the previous (rejected - long story) 2008 defender. so unless my dealers had a proper moment (as if ha) or were talking 2 different barriers im confident its riveted.
This is what I'm talking about.
that appears to be the one -
| Miserableolgit Joined: 14 Sep 2007 Location: Suffolk Posts: 70
I have the pukka cargo / dog guard fitted to mine but don't recall there being any rivets involved. |
| Sonic3d Joined: 28 Jan 2008 Location: Ross on Wye Posts: 136
If you are referring to these rivets they are on every 110 station wagon and double cab
yep those are the ones - Id assumed as they werent painted they had been replaced to install structure.
Yep they are unpainted. I was told that was only on the Australian models, but never looked closely at the UK ones to see if they were too.
thanks
| red Defender Joined: 11 Feb 2008 Location: Cornwall Posts: 35
The rivets you are refering to are left unpaited during the build process. The panel that they hold on is the last to be fitted. All panells are sprayed, hung on a rack and built onto the vehicle, then that small panel is riveted on. |
Cheers charles
My pleasure |
| All times are GMT |
