Forum · Gallery · Sponsors
Home > Maintenance & Modifications > Aux Power Socket
Reply to topic  Down to end
mse
2008 Defender 90 Puma 2.4 XS CSW Manual Java Black
Aux Power Socket
Just wondered how anyone has tackled this on their 90's - im looking for options, before moving on to a second battery (which is another thing to consider).
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #2930 26th Jul 2008 4:31pm
TJ101
2007 Defender 110 Puma 2.4 XS CSW Manual Cairns Blue
Mike,, If its 12v aux sockets you mean,, There are meant to be 2 power supply feeds fitted , certainly on the 90 and 110XS,,
I found one on mine,, behind the speaker panel, r/hand rear,, Black and Purple wire, Their is meant to be a second one somewhere, about halfway back,, Both projected by a fuse in position 2 (Accessory socket) in the under seat fuse box
_________________
RRS G4, R8, 90 V8 Hybrid
www.wessex4x4response.org.uk
http://forum.innovate4x4.com
Post #2935 26th Jul 2008 8:38pm
mse
Great - i shall have a look...although i might wire something direct so i can plug the roof tent light in without the key.
Does the socket fit in that same panel?
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #2936 26th Jul 2008 8:42pm
TJ101
Mike
I fitted a socket (these http://www.towsure.com/product/1923-Cigar_Lighter_Socket ) either side of the rear door, into the speaker panel , If you use the factory loom, they are rated at 20amp, and always powered,, I runs the tent power feed from one, the other is used for the Engle, with a low voltage switch
My power feed was dead, until i trace the lead back, and found a joint connector fixed to the brake servo bracket under the bonnet, somehow, this connector was not making contact, !!!
_________________
Post #2937 26th Jul 2008 8:57pm
mse
Thats good news - ive got one of those (actually in its own housing)
So if i can find the Black/purple wire then i may be in business with a none switched feed - thats great news thanks.
hopefully it will just work - i assume no additional fuses required as it uses one in the box?
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #2938 26th Jul 2008 9:16pm
diffbeer
Which one is the positive ?
Question
Post #4780 18th Nov 2008 3:56pm
View user's profile Send private message Reply with quote
TJ101
diffbeer wrote:
I found one on mine,, behind the speaker panel, r/hand rear,, Black and Purple wire, Their is meant to be a second one somewhere, about halfway back,, Both protected by a fuse in position 2 (Accessory socket) in the under seat fuse box
Question
Purple wire,, if i remember right ! easy to test,,
_________________
Post #4783 18th Nov 2008 4:58pm
Sonic3d
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Manual Bonatti Grey
Purple Thumbs Up
_________________
D3 Gone A5 Quattro Rocket Arrived + 90 County HT Gone 110DC XS Arrived
Post #4785 18th Nov 2008 5:09pm
Grockle
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Manual Tonga Green
Can you get a power socket that can be fitted in the cubby box ?
_________________
2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5213 2nd Dec 2008 5:36pm
TJ101
Not from the factory
One of the reasons we all run defender, is the ability to do what ever you want,,
Would be easy to run a power socket to where ever you want
_________________
Post #5214 2nd Dec 2008 5:58pm
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2009 Martin Lewis
