Home > eBay & Bargain Spots > 37" wheels |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
27th Nov 2015 10:46pm |
Think from the look they may have been a bespoke set made by Matt Lee. Hence the reason they flew. If you go through life with your head in the sand....all people will see is an ar5e!!
27th Nov 2015 11:23pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Probably not road legal what do you reckon?
Matt made me a set of 18's and they are not stamped with any codes or numbers. As a result I am reluctant to use them 130's have feeling's as well you know |
28th Nov 2015 9:40am |
The two sets I had one from D4X4 and the second from a forum member didn't have markings either. Could be they had been covered up by the coating process not sure. Hasn't stopped me from using mine as only the beadlockers he used to make were advertised 'not for road use' they were also notoriously difficult to balance if you did intend to use them on-road. If you go through life with your head in the sand....all people will see is an ar5e!!
28th Nov 2015 9:54am |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
What would make them a special and not road legal?
29th Nov 2015 9:00pm |
They are not stamped with a load rating. 130's have feeling's as well you know
30th Nov 2015 7:02pm |
30th Nov 2015 10:36pm |
