![]() | Home > Puma TDCi > Puma EGR blanking plate FREE :-) |
| mrwoo Joined: 03 Jan 2008 Location: Cheshire Posts: 80
| mse Joined: 06 Apr 2008 Location: UK Posts: 529
I dont think fooling the MAS will work though becuase this sensor has to read the actual ambient air flow so the ECU knows how much diesal etc is required. I think the range on the MAS needs to be adjusted so it can accept the higher air flows.
| AndrewS Joined: 10 Apr 2007 Location: Pembridge Posts: 371
Here is a picture of what you are blanking off
| bell-auto-services Site Sponsor Joined: 08 Jul 2007 Location: North Yorkshire Posts: 156
Humm , Now im wondering if i made a plate that had ALL the holes that the EGR cooler has got but all small , EG 19x2mm holes in the same place as the originals then you are not blocking some of the holes but are restricting them all slightly.
I have been running with a 12mm hole (biggest dril bit I had) and so far there is no warning light on, I have driven more than 3 driving cycles, the amount that would normally put my light on. I dont think the engine is quite as smooth as a fully blanked EGR but I think that is to be expected.
| eric67 Joined: 17 Nov 2008 Location: FRANCE Posts: 1
Hi All,
| Verdone Joined: 30 Apr 2008 Location: Gent Posts: 52
Just took mine out, never found a way to disable the warning light fully |
| All times are GMT |
