Home > Td5 > Changing power steering pump |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
There was a feature in last months' Land Rover Owner I think with a step by step. My old Td5 had ATF in, no problems in around 80K miles.
26th Nov 2015 2:15pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Thing is I have about 7 litres of ATF left (used it for tractor hydraulic fluid) so will use this to keep costs down.
Haynes manual advises putting axle stands on front but speaking to independent he said no need!! Any way have ordered steering pump from ACS who recondition old pumps and sell them for £89 with proviso you give them your old pump. Has 18 month unlimited mileage warranty with it Looking forward to doing it. [/list] |
26th Nov 2015 8:42pm |
It's got to be 18 months since I did mine, no major drama apart from make a note on how the belt runs, which side of the pulleys etc. It gets a little embarrasing to be struggling to put the belt back on and it won't quite fit even prompting you to change the pulley on the pump just in case the second hand one was a different size. Quick check of the Haynes book of Lies and all just fell into place
26th Nov 2015 9:09pm |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 499 |
Tommo, do you have any details for ACS ?
My steering pump is leaking, don't know if it's just a replaceable seal or not. |
27th Nov 2015 5:56pm |
Hi Martin
phone them on 01827 259699. They operate an exchange system which is why they are cheap, you have to send them your old pump and this then activates the 18 month warranty. cheers Tommo |
27th Nov 2015 6:32pm |
Cheers Tommo I'll give them a call.
27th Nov 2015 10:22pm |
Well pump changed!
Steering fluid is rank...what is the best way to drain the whole lot and replace?? |
28th Nov 2015 9:37pm |
When I changed the steering box on my D2 I siphoned as much as I could out of the reservoir then attached a brake bleed hose to the bleed nipple and left it to drain until it stopped. It's nigh on impossible to get it all out in one go so refilled and repeated, should have got the majority of the old out.
29th Nov 2015 1:27am |
A cautionary tale
Although I successfully fitted the pump I could not get it to pressure up Took all day Saturday and Sunday and took a day off on Monday to try to sort...turned out I had not put on the rubber o ring on the connection to the pump. Once this was done it was fine. Checked the Haynes manual and also the LR mag that featured changing pump and there was no mention in them about this tiny little rubber ring that caused all the problems. anyway now all good. |
1st Dec 2015 8:38pm |
Boyd Member Since: 11 May 2014 Location: Le Saint Posts: 172 |
Sorry to bring up an old thread but.....
any idea which LRO magazine had the feature in it? I am mid change at the moment and there is obviously a bolt i can't see that i'm missing as the ruddy thing won't move! 2003 Zambezi Silver TD5 110 XS SW overland prepped.... 2004 Santorini Black TD5 110 XS SW left hooker for sale! 2004 Alpine White TD5 110 left hooker (work in progress) |
29th Nov 2018 12:43pm |
Hi Boyd
from memory there are 3 bolts to remove once the pulley is removed. Have a look at the landrover defender workshop manual on line if stuck. good luck Tommo |
29th Nov 2018 9:15pm |
All done thanks, saw it on the workshop manual blown up image.... hadn’t realised the lower two bolts both went through the front bracket and into the main casting. 2003 Zambezi Silver TD5 110 XS SW overland prepped....
29th Nov 2018 10:04pm |
