Forum · Gallery · Sponsors
Home > Maintenance & Modifications > Chequer Plate Wing Tops
Reply to topic  Down to end
chalky
Slightly confused with the wing top lengths between 90 / 110
They seem to be of different lengths ? according to plate lenghts surely the wing tops are the same size ?
Also will the TD5 ones fit the TDCi ? for some reason my local dealer says not.
As always any info is apreciated.
_________________
DEFENDER XS CSW 08 TONGA GREEN
Post #4716 16th Nov 2008 12:22pm
View user's profile Send private message Reply with quote
Sonic3d
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Manual Bonatti Grey
There are 2 lengths of wing top chequer plate. The wings on TD5 and TDCI are the same Thumbs Up
Short (No aerial hole)
Long (Aerial hole on)
_________________
D3 Gone A5 Quattro Rocket Arrived + 90 County HT Gone 110DC XS Arrived
Post #4717 16th Nov 2008 12:32pm
The Boy
The old (td5/tdi) long ones don't really fit the new Puma as the bonet is wider and can chip the paint work but I got round this by sticking some household sticky door seal foam under the lip of the bonnet. The new long top for the Puma is jsut a bit narower and a little shorter.
Post #4719 16th Nov 2008 12:54pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Manual Zermatt Silver
As mentioned the older wing tops won't fit the Puma, though from what I was told most people are fitting them Confused Unfortunately when I tried this I found that the genuine 3mm checkerplate was not going to fit under the bonnet without significant damage to something. The tollerances on the bonnet closure seem to vary - fance that on a Land Rover Shocked - anyway I ended up getting the correct one for the Puma. The new model's plate is not only smaller in size its also much more costly over here Big Cry
The differences between the Td5 and the TDCi are the bonnet is about 1" wider on either side at the firewall and about 1/2" wider on either side at the front. This means it overlaps at both ends and you need at least 4mm gap to stop it contacting the checkerplate.
If you're not buying 3mm and only getting a lighter weight plate then check it out and see what will fit.
_________________
110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #4720 16th Nov 2008 1:16pm
Sonic3d
The kit i fitted was exactly the same as the genuine TD5 one (annodised silver) i just adjusted the the 2No rubber stops and catch on the bonnet and all is well Thumbs Up
I`ll try and take a photo later Thumbs Up
_________________
Post #4721 16th Nov 2008 1:20pm
dm_td5
Wouldn't have helped me, I looked at that but my bonnet has a very small gap at the rear from about the aerial back. Heaps of room at the front and I could have wound the stops out a little to be safe. Unfortunately not a lot can be done at the hinge end. I've now looked at 2 other Puma's, one would have fitted no problems, the other was better than mine but still probably not a good fit. Like I said - tolerances on the bonnet closure seem to vary.
_________________
110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #4723 16th Nov 2008 1:29pm
chalky
Thanks so far !
Just checked my tolerances and they are tight !
So for arguments sake the long ones are TD5 or older and the shorter and not that i have noticed thinner ones are TDCi ?
_________________
Post #4724 16th Nov 2008 2:02pm
dm_td5
If you buy the genuine LR one's the only difference is in the length and width of the plates. They are both 3mm thick. The Td5 and earlier are longer and have a hole for the aerial, the Puma ones are shorter and not as wide at the front end.
_________________
110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #4735 17th Nov 2008 6:38am
vogue se
Belgium 2008 Defender 90 Puma 2.4 HT Manual Alpine White
Has anyone a picture where you can spot the difference?
_________________
My Kyoto is fantastic
Post #4738 17th Nov 2008 11:42am
dm_td5
Didn't think of it when I fitted them, but I'll see what I can do with the camera and photoshop tomorrow (it's very dark here now Wink ). I have Tdi parked next to Puma and both have the wing top plate fitted. So should be able to do a scaled overlay.
_________________
110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #4739 17th Nov 2008 12:05pm
chalky
Thanks guys, This is most helpful.
_________________
Post #4740 17th Nov 2008 12:28pm
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2009 Martin Lewis
