Home > Tdi > Bouncing Boost Gauge Needle
schweps
Turkey 2005 Defender 110 300 Tdi HT Alpine White
Hi,
I've installed a boost gauge on my 300tdi engine.
The pressure for the gauge is taken just after wastegate actuator Tee piece as referred.
@ idle, while the vehicle is stationary, the needle is bouncing around zero value.
Is this bouncing normal?
Somewhere I've seen a message saying negative (vacuum) values shall be read at idle on these tdi engines, is that correct?
Cheers.
Senol
Post #461214 7th Oct 2015 9:32am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I had the same problem with my old TDi.
The pressure inside the manifold fluctuates at a very fast rate and produces a wobbly needle that makes accurate reading impossible.
There is a little device that can be connected in line with the pressure hose - sadly I can't recall what it is called! It allows boost pressure to reach the guage, but it stabilises the pressure so the needle is slower to react to changes. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #461244 7th Oct 2015 11:12am
SiWhite
Edit - I knew there was a thread somewhere...
http://forums.lr4x4.com/index.php?showtopic=11183
Looks like you need a needle valve for a neat job My blog - www.anacreinhampshire.blogspot.co.uk
Post #461246 7th Oct 2015 11:14am
schweps
Thanks for your prompt response,
I got the idea.
What about (-) reading?
Post #461248 7th Oct 2015 11:20am
SiWhite
There shouldn't be a vacuum detected in the inlet manifold. My blog - www.anacreinhampshire.blogspot.co.uk
Post #461249 7th Oct 2015 11:21am
schweps
Ok. Thanks.
Post #461459 8th Oct 2015 6:10am
TiredGeek
When I fitted a boost gauge I had exactly the same problem, wobbly needle.
I got the little tube off a WD40 can and put that inside the pipe to the gauge and then tied it really tight with a tie wrap to make sure the air had to go through the little tube. The result was a dead steady needle Smile The doctors said it's OK to listen to the voices, just not to do what they tell me!
Post #480838 9th Dec 2015 10:13pm
schweps
Hi,
I used a pneumatic flow control valve as adviced.
Post #481383 11th Dec 2015 8:41pm
