Forum · Gallery · Sponsors
Home > Puma TDCi > Outside air temperature
Reply to topic  Down to end
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Manual Cairns Blue
On an 2007 XS is it possible to display the outside air temperature on the instrument display. Pesumably the vehicle knows from the ambient air temperature sensor for the air con what the temperature is and I believe the instrument display panel is from either the new Disco 3 or Feelander, both of which presumably display the outside temperature somewhere.
Post #4575 8th Nov 2008 11:02pm
View user's profile Send private message Reply with quote
mse
2008 Defender 90 Puma 2.4 XS CSW Manual Java Black
The Freelander I have (F2) displays Avg Speed, Range, MPG, Trip, key information (washer low) and maybe something else on the instrument display - but i assume all this is controlled by the BCU anyway so would the OAT - which is displayed on the central display.
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #4582 9th Nov 2008 5:10pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Manual Bonatti Grey
Croytec anre now doing an add on for your radio which will allow it to show the OAT vai, i believe, the ariel.
Its in LRW this month, and is abour £90
_________________
We are competing in the Macmillan 4x4 UK challenge 2009.
Please support us at:
www.justgiving.com/team44
Post #4601 10th Nov 2008 1:48pm
mse
i was wrong - top right ext temp on the central clock - its amazing you look at something over and over!
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #4603 10th Nov 2008 3:39pm
Grockle
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Manual Tonga Green
Mike,where's the outside air temp on the TDCI
_________________
2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #4970 25th Nov 2008 3:03pm
mse
Dont know - i was talking about our f2
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #4971 25th Nov 2008 3:24pm
Grockle
oops, didn't think I'd missed it.
_________________
2.4 90 XS
Post #4974 25th Nov 2008 5:02pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Manual Bonatti Grey
Has anyone composed OAT display neatly into the new dash?
It getting colder here and I am looking for the way to know if it is below or above zero and how much.
Cheers!
_________________
Janusz
www.yahodeville.com
Post #5017 26th Nov 2008 11:26am
mrwoo
2007 Defender 90 Puma 2.4 CSW Manual Zambezi Silver
I haven't yet but I used to use one of these on my old Land Rover, I might get one for my TDCi:
http://www.maplin.co.uk/Module.aspx?Module...;U=strat15
Post #5019 26th Nov 2008 2:37pm
cobs
maplin display looks good value and croytec radio display is interesting though expensive however i think all the 'bits' (OAT sensor and display) are already on the vehicle - if only I knew where the wires went..........
Post #5079 27th Nov 2008 9:12pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Manual Keswick Green
The sensors already are, there's loads of info there to tap into (you can use a scangauge - http://www.scangauge.com/ to access it from the OBDII port).
If the bits of the binnacle that display info on the FL are still there (not removed for the Defender?) then it would be great to link it back up..?
Post #5094 28th Nov 2008 9:23am
Grockle
Ads90,if the facilty for it to be powerd up is their let us know mate.
_________________
2.4 90 XS
Post #5108 28th Nov 2008 4:43pm
Ads90
I would/will do, but I'm not an expert on the electronics (or any other part for that matter) - all I know is all I've said I'm afraid!
I was rather hoping someone else would answer that for us! Confused
I'm tempted by the scangauge, just not sure where I'd put it - I like to keep the dash uncluttered (I'm a bit OCD like that!). So would be great if the instrument panel could be put to more use...
Having said all that, we know the buttons on the front are 'fakes', so it may well be that all the necessary parts have been deleted. Sad
Post #5117 29th Nov 2008 9:44am
mse
What buttons??all mine work.
I would suggest/suspect the central screen you are talking about is not there - if your lucky not connected, but then to connect it (been a long time since ive done anything LCD related) you would need to power it, some sort of control module for it and then the input. I doubt it would know how to display any input without some form of chip - which may be there as part of the instrument control unit, but likely part of the F2's BCU equiv.
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #5121 29th Nov 2008 10:18am
cobs
Well I had a look at a mate's Discovery today and this is where the outside temp is displayed:
The display pod looks identical to the Defender's apart from a different speedo (130mph vs 110) - maybe the Freelander's is the same - this is the Defender pod:
Looking at the back of the instrument pod it seems there is a single connector so I would guess that the instrument pods are standard units - without disconnecting it and taking it apart however I can't say if the lcd display is in there but just not used - the only clue seems to be that in the handbook it says that in the Gulf States this lcd is used for an overspeed warning indicator - this is the connector for the Defender pod:
I haven't located the OAT sensor yet but suspect someone will know where it is - this project may have to wait for warmer weather.........
Post #5126 29th Nov 2008 6:20pm
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2009 Martin Lewis
