![]() | Home > Puma TDCi > 110 rear springs specifications |
| Eduardo Joined: 28 Aug 2008 Location: SANTIAGO - CHILE Posts: 130
Hi there!
| dm_td5 Joined: 20 Jul 2008 Location: Northern Territory Posts: 120
If I remember I'll look under the back of my 08 110 SW 7 and see what we get in Australia. I'm about to put heavier ones in the front as it dropped about 15mm and it handles a bit worse since putting an ARB bar and 9.5t Warn winch on the front.
dm-Td5.
| mse Joined: 06 Apr 2008 Location: UK Posts: 529
More than likely.
| Landy nut Joined: 22 Dec 2007 Location: In hiding Posts: 26
I have one of those ARB beasts up front and they are seriously heavy. When I fitted it, it made the front more wallowy and the ride was harsher and it dropped a fair bit. They are seriously heavy, but I had some idiot drive in to the front of me in a twin-rear axel flatbed lorry and all it did was put a dent in it that was barely noticable, so it just got a quick touch up paint and as good as new!!! They are awesome. Just wish it did not cut down my approach angle as much. I switched to LR genuine springs and got heavy duty ones and they sorted it nicely. They are only about £70 a pair and I think the colour coding is white:white. I know a few people who change the shockc, but much prefer original springs to aftermarket ones. Well, as long as you dont need a lift!!! Having said that, after fitting my springs, it levelled out beautifully to sit level with the rear. I run a double cab with 1 ton rear springs, so it REALLY solved the problem.
Please...
| AndrewS Joined: 10 Apr 2007 Location: Pembridge Posts: 371
Thanks Andrews |
Sales Counter |
Thanks a lot! |
| MK Joined: 28 Aug 2008 Location: Surrey Posts: 14
Any luck finding out specs for the new springs? |
Nop,
| All times are GMT |
