Forum · Gallery · Sponsors
Home > General > Sand Tyres
Reply to topic  Down to end
rick
Australia 2008 Defender 110 Puma 2.4 SW Manual Stornoway Grey
Sand Tyres
Just a question on tyres - as 99% of my offroading will be on the beach/soft sand (not gravel and rocks), are the stock standard skinnys (deflated to 15psi) enough? Would wider, all terrains provide much more benefit other than looking better? I've been told that the standard alloys aren't really designed for a wider tyre so, to my mind, going wider means new alloys as well - an expensive move for perhaps not that much benefit?
One other question, is there any benefit going with steel wheels instead of new alloys (eg Zu Rims) - is one better than the other?
Your comments would be appreciated.
Cheers,
Rick.
_________________
2007 RRS TDV6
2008 Defender 110
Post #4468 4th Nov 2008 2:17am
View user's profile Send private message Reply with quote
foz.in.oz
Australia 2004 Defender 110 Td5 SW Manual Bonatti Grey
All terrains won't offer any better performance over road biased tyres in sand. In fact the balder the better so as not to break up the surface. However the buttresses at the edge of the tyre tread can make a difference. What you need are tyres that float on the surface. The butressess help if you get into rutts. The standard skinnies work very well if you deflate them as you suggested. Beware though that running tyres this flat at speeds higher than 40kmh can cause the carcass to heat up and fail. Avoid the brakes, keep the power on and you should be fine.
_________________
Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #4494 5th Nov 2008 3:29am
AndrewS
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Manual Alveston Red
On a recent trip to Morocco a new standard 110 with the horrendous looking standard tyres on went everywhere it was pointed. You can put wider tyres on the standard rims I think Sonic and Bogblaster are running 285 on standard alloys.
Steel V Alloy
Steel is better as they are stronger. However the Zu rims are impact tested and rated a lot higher than the standard alloys. If you are going to hit rocks a speed get steel if not then stick with the alloys Thumbs Up
Hope this helps
Post #4495 5th Nov 2008 7:47am
rick
Thanks for the advice guys - just what I needed. Cheers, Rick.
_________________
2007 RRS TDV6
2008 Defender 110
Post #4522 6th Nov 2008 2:42am
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2009 Martin Lewis
