Home > Puma (Tdci) > Barrel lock part number please?
ZeDefender
Hi all Smile
Please can someone tell me the part number for the Puma driver's side barrel lock (central locking etc.)? Mine's seized and keeps locking me out Big Cry
I can't seem to access the russian microcat site any more Evil or Very Mad
Come to think of it, please can someone point me to a working microcat site?
Matt Tell someone you love them today because life is short.
Post #449922 28th Aug 2015 7:17am
dorsetsmith
CWC500190
Post #449932 28th Aug 2015 8:07am
ZeDefender
Cheers Bow down
Post #449935 28th Aug 2015 8:23am
dorsetsmith
if look on the gallery pic too
Post #449939 28th Aug 2015 8:32am
ZeDefender
Ordered Thumbs Up
Might be able to drive the bloody thing again soon Rolling Eyes Tell someone you love them today because life is short.
Post #449952 28th Aug 2015 8:54am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Just changed mine. How is it that it is cheaper to buy all genuine locks (ignition included) cheaper than the two front locks I needed?
Post #450150 28th Aug 2015 6:32pm
ZeDefender
I can't change the ignition lock due to the security sheath so I'll have 2 different keys Rolling Eyes Tell someone you love them today because life is short.
Post #450187 28th Aug 2015 8:26pm
gazman
What's a security sheath
Post #450214 28th Aug 2015 9:44pm
mk1collector
It would be much cheaper to buy some graphite powder and spend half an hour wiggling the key in the lock and turning it left and right till it frees up. Ray
My build thread
Post #450225 28th Aug 2015 10:13pm
When I bought my Defender the driver's door lock barrel was so seized that the key wouldn't go in, let alone turn. I bough a new lock set,but before fitting thought I'd try freeing it off. Half-an-hour with the aerosol penetrating oil and manipulating the key had the lock working fine. Since then I make sure that I use it every month or so to keep it working and it has been ok ever since.
Post #450228 28th Aug 2015 10:41pm
ZeDefender
Been there, tried that - after an hour using various tools, graphite, carb cleaner, anti-seize etc. i could get the key in and turn it forward to unlock...however when I turn it back again to remove it, it locks (doesn't "freewheel") and triggers the CDL and alarm. Only then can I get the key out Rolling Eyes
It's not the pins that are the problem but rather something to do with the rest of the mechanism. In any event, the current lock chronically seizes up no matter what I do (since new), so I'm changing it anyway. Last night I found a temporary solution - I use the spare key to unlock the door then leave it there whilst driving. When I get out I have to lock the door to take it with me. Only the perimetric alarm is armed but that's good enough and there's no nasty noise Thumbs Up
The ignition barrel sheath info is here (and a lot of other places)
http://www.defender2.net/forum/topic17090....arrel+lock
It basically stops someone hammering a screwdriver into the lock to split it and then twisting it.
Two things to bear in mind though:
a) once it's fitted you cant get it off to change the lock without a LOT of work
b) some have reported that the newest locks have a different design (can't confirm this)
Post #450251 29th Aug 2015 7:14am
It might be worth removing the door card and checking the gubbins behind the lock inside the door. It sounds to me as though just changing the lock barrel may not solve the problem.
Post #450258 29th Aug 2015 7:50am
mk1collector
If it's that bad I'd take the handle out and remove and clean the barrel the make sure the spring is still intact and all the rods are properly adjusted then it should all work perfectly. There's no way I'd put up with a seperate key for such a simple mechanism. Even your original barrel can be stripped totally down if needed. Ray
My build thread
Post #450283 29th Aug 2015 9:32am
ZeDefender
That's the idea Smile
But I've ordered the new barrel anyway just in case Thumbs Up
Post #450301 29th Aug 2015 10:54am
