Home > Maintenance & Modifications > Bonnet Insulation - Install with Pictures. |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 |
I had a few hours spare this morning so decided to crack on with my planned bonnet insulation project which is part of a much larger sound insulation project.
Anyhow, I decided on a very crude technical test when I remembered I had an old analogue radioshack sound meter which I used to set up my surround sound system at home. Its a bit crude and I didn't have time to go for a drive and record levels so a stationary idle had to do! So pre-mod the readings were: Outside (30cm from grill, level with bonnet): 67 dB Inside (30cm from dash, level with top): 57 dB On to the job: Step 1: Under the bonnet was fairly clean. So just a wash off and then a full degrease with panel wipe. Step 2: Dynamat Extreme (Supplied by Simon from MPS - Top guy to deal with and the best price by far!). Didn't go too mad but applied to the obvious accessible outer sections. I noticed some resonance to the inner skin too so simply placed some strips to kill that off too. Wasn't going to go too mad! First observation: Bonnet now closes with a lovely resounding thud. Previously it was something of a clatter!! Dynamat certainly working in that regard. there is also something quite nice about tapping a clad panel. More "steel sheet" than "tin can" Oh and if you're wondering why its black in colour? Its so the blood from your fingers doesn't show. the edges are sharp!! Step 3: Cut and fit an insulated blanket. Sourced mine (on something of a late night surfing whim!) from evilbay: http://www.ebay.co.uk/itm/261912839993 Again as it was so warm it was seriously sticky! Careful thought required on cutting and fitting. You only get one chance! Step 4: Drink tea in midday sun! (Very British!) So what are the results of the re-test: Outside (30cm from grill, level with bonnet): 66 dB Inside (30cm from dash, level with top): 55 dB Hmmm so hardly much to write home about but I'm convinced (could just be the heat effecting my brain) the sound is "deader". Guess I should have taken it on a run for a proper sound test. Oh and one last thing. In this heat Dynamat is difficult to remove from its backing. Its sticky enough when cold, once warm its gunky! Had to move to cutting inside the garage Hope the above is useful to someone. TTFN Barney |
30th Jun 2015 1:36pm |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
very good write up giving me ideas on doing my puma bonnet
30th Jun 2015 2:22pm |
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 |
Sort of on the edge of the topic, but a firm called Faber Acoustical do a free iPhone decibel meter app which works from the iPhone microphone. Very good with a paid for more complex one if needed. Ian One wife - livid
30th Jun 2015 4:52pm |
30th Jun 2015 4:54pm |
Sorry double post. Ian One wife - livid
This is what I'm hoping. I'm just in the middle of doing the rear. Hopefully will do the front at the weekend as long as 'The Rascal' doesn't make me do the gardening |
30th Jun 2015 10:23pm |
Cheers will take a look. |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
VERY USEFUL Barney!!! Many thanks mate! Pete. YOLO... You Only Live Once... |
25th Aug 2015 9:56am |
Hardly seems worth the effort for what appears to be such a minimalistic static sound reduction? Placebo effect may compensate though. If you go through life with your head in the sand....all people will see is an ar5e!!
25th Aug 2015 10:21am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I'm sure that when the sound gets louder due to increase in engine revs then it'll make a bigger difference, one or two db doesn't sound like much but I think it works on some sort of scale, so a few db less can mean half the noise level, something like that anyway, I'm probably talking twaddle as always though.
Cheers for the write up, link and pics, I'm thinking of doing this soon - as well as the interior |
25th Aug 2015 10:47am |
Be aware that fitting bonnet insulation can actually increase cab noise apparently. Also the phone applications for noise measuring are only accurate when static.
http://www.defender2.net/forum/topic20069.html?highlight=db If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Aug 2015 11:11am |
Maybe I will just wear some noise cancelling headphones then!!
2 pairs actually! YOLO... You Only Live Once... |
25th Aug 2015 11:14am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
That's probably cheaper too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
26th Aug 2015 8:51pm |
and you won't be able to hear the wife! Double win!! |
26th Aug 2015 8:59pm |
