Home > Wheels & Tyres > Wobble / vibration through steering wheel at 50 to 55mph |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
Experiencing EXACTLY the same thing at the moment.
Been running 265/75x16 BFG's on ZU's for years without any problems whatsoever. Fitted 265/75x16 ST Maxx on Sawtooth's and I also have a wobble at 50-55MPH. Tyres are balanced ok and there are no problems at higher or lower speeds but I get the wobble at this speed regardless of the road surface. I am going to check the swivel pre-loads but it is a brand-new LRGP axle and was fine with the old wheels / tyres fitted. ONE LIFE, GET IT! |
30th May 2015 6:23pm |
Worth checking the suspension bushes, mainly the Panhard arm and Radius arm bushes. Get a good pry bar and check for movement.
30th May 2015 9:39pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
are both of the new sets of wheels the 'copies' by any chance?
30th May 2015 10:48pm |
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 307 |
Mine are.
Another long shot is, I have locking wheel nuts, could these throw the balance out if they are a different weight to the standard nuts? |
31st May 2015 7:39am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
i got sawtooth with bfg all terrains ,mine are spot on.
i had that problem with bfg mud terrains though |
31st May 2015 7:56am |
Williamthedog, are your sawtooths aftermarket and what pressures are you running?
31st May 2015 8:05am |
yes mine are copies.
i run them at 33psi, but i have got rack and rooftent fitted. no wobble at any speeds ,the mud terrains would go out of balance all the time. saved them for winter use and lower speeds |
31st May 2015 8:34am |
Cheers for that, next stage is to balance the rear ones again and swap them over to see if that helps.
31st May 2015 8:42am |
