Home > Technical > Rear Reverse/Fog Lights |
The only possible drawback I can envisage carrying out this modification on any other truck would be that if you wanted to ft a swing away wheel carrier later on, you'd be stumped. If you go through life with your head in the sand....all people will see is an ar5e!!
30th May 2015 2:25am |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
Both those points definitely valid I wouldn't put LED bulbs in holders on the other lights, but as you said since it's reverse I thought I'd give them a shot. Have been toying with the LED NAS lights idea, but I wanted to keep it future proof - for example, if I break one down the line, would I be able to pick up a single replacement that is the same as the others, or will they have become obsolete and I'd have to buy a complete set? At least with the standard lights, they will probably be obtainable indefinitely.
And yes, the swing away carrier problem did cross my mind once I'd fitted them The bumperettes that are fitted wouldn't allow one anyway. Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
30th May 2015 11:24am |
I recently went Wipac LED and was considering 'doubling up' as I thought it was a great idea but I didn't look at my 90. Needless to say I hastily cancelled the extra fog and reverse when realising my error. As for the bumperette I reworked mine grinding off the original brackets subsequently fitting different angled brackets to pick up on other securing bolt locations to the swing away.
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th May 2015 11:29am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
Looks good Mal.
30th May 2015 12:27pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
Not necessarily, depends on the make of carrier. People often say that you can't have a full compliment of NAS lights and / or a swingaway carrier and / or bumperettes but my vehicle has them all. [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ONE LIFE, GET IT! |
30th May 2015 12:28pm |
What bumperettes are those? they look like mine but I never bought them the previous owner did so didn't know the make.
30th May 2015 1:54pm |
What carrier is that too Litch?
Your truck really does look cracking with those grey Sawtooths and ST Maxxs! Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
30th May 2015 3:06pm |
