Home > eBay & Bargain Spots > New JW speaker Evo 2 LED headlights on eBay |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Might be worth keeping an eye on these New And Unused Land Rover defender JW speaker Evo 2 LED headlights
Might end up being a bargain! http://www.ebay.co.uk/itm/Land-Rover-defen...33a1675a48 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
22nd Apr 2015 4:24pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 709 |
Sshh!!
22nd Apr 2015 5:30pm |
Not such a bargain after all. Thought the price would go up. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Apr 2015 4:09pm |
Yep! Probably end up some one paying more for them than they could have bought them from a supplier! For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
25th Apr 2015 4:51pm |
Due to offence, quote removed..... If you go through life with your head in the sand....all people will see is an ar5e!!
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 26th Apr 2015 10:40pm. Edited 1 time in total |
25th Apr 2015 5:01pm |
Trucklites I guarantee are better as are another well known brand......
Just knocked my original JWS for less than the starting bid as a favour to a fellow forum member. ALL confidence lost in the JWS and will never purchase the brand again. Absolute rubbish unless they sort out the IP rating. 'Forgotten promises' and any perceived warranty are worthless too in my experience. They've gone and I'm well shot......purchaser knew exactly the issues but at nearly 10% of the original cost a bargain was struck where everybody was happy..... Goldfish are extremely upset.......the ones that used to live in the water inside as they no longer get their scenic trips out at 70mph...... Bit like these.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Apr 2015 12:29am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Just be careful with trucklites as the polycarb cover is very soft so careful when cleaning
Must say I never had the same problems as Mal with my Speakers but thats not to say there aren't any TBH I found the trucklites woful in terms of performance i'll see side by side Speaker vs Nolden when the AB turns up |
26th Apr 2015 9:24am |
http://www.defender2.net/forum/topic25769....ndensation
I never suffered with the second affliction which was the corrosion. http://www.defender2.net/forum/topic22435.html Time will tell if the latter ones were any better as the issue didn't manifest itself for some time. The IP rating didn't upgrade/improve and as a result neither did my confidence in the brand. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Apr 2015 11:02am |
Well if you must park it in water so as not as far to walk to the current vessel you have been assigned to
26th Apr 2015 1:26pm |
Dependant on time of day and tides I could do with a longer snorkel too. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Apr 2015 1:38pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
If we are quoting pass problem's, Then the outcomes should also be posted from that thread
I also, after trying all 3 current LED lamps makes at the same time, found the trucklites and Holden below par compared to JWS's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
26th Apr 2015 6:32pm |
It was there already.....and immaterial now...... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Apr 2015 7:28pm |
Ideally if I was to spend that sort of money on a new pair, I'd get the noldens in either black or dark chrome. One day I might pluck up the courage (and the funds) to get some. Just prefer the look of them, I've got some nolden 90mm drls and am very pleased with those
26th Apr 2015 8:23pm |
26th Apr 2015 8:54pm |
