Home > Td5 > Possibly out of luck....... |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
no need for a lab report...if it filling up and it smells of derv then the washers need changing...unless its to late?
31st Mar 2015 6:33pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Only a very slight rise and I always work off oil samples. It costs me nothing and I can see the wear rates then and decided if further investigation is required. Its the diesel engineer in me, I can't help it
Fuel dilution has to be really bad for it to be detected by smell |
31st Mar 2015 6:36pm |
Dammit. Fuel dilution detected . Time to hoik the squirters out.
13th Apr 2015 11:46am |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
I had similar on my 2001 90 Td5. With yours being the later 15p engine its less likeley you have a cracked cylinder head. I have a 10p
However 2,000 miles *touch wood, and the oil level isnt rising and doesn't smell diesely, so that's a promising sign, that the injector seals have done the trick!! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel. 2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
13th Apr 2015 4:15pm |
I'll get the crack detector out and give it a thorough check as I usually do. I'd strongly recommend sampling your oil if you have any suspicion. I deal with lots of cases of fuel dilution every year on various different types of engine and I can tell you now by the time you can smell it it's bad !!
13th Apr 2015 4:28pm |
Well injector seals done, no cracks found so let's see what the next sample shows
19th Apr 2015 11:55am |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
Good work and good to know about the longevity of these engines
19th Apr 2015 8:12pm |
